There are the typically aluminum plates that are in the front corners of the cabinet - evidently to stop folks from sticking a wire there to actuate the coin mech. I need a pair for a 60s Gottlieb.
Quoted from swampwiz:There are the typically aluminum plates that are in the front corners of the cabinet - evidently to stop folks from sticking a wire there to actuate the coin mech. I need a pair for a 60s Gottlieb.
Inside or outside the cab?
If inside, aren't those just sheet metal covering the ends of the bolt holes?
If so, just bend as appropriate on a metal brake and staple them to the cab.
Leg bolt armor plate.
https://www.marcospecialties.com/pinball-parts/P-3914
I’ve used these on a couple of Gottliebs I’ve restored.
Quoted from ForceFlow:Inside or outside the cab?
Inside the cabinet. Now that I think about it, I could get someone on Etsy that does sheet metal stuff to cut some pieces, drill a pair of holes and then put in a 45-degree lip on both sides. Maybe I could get copper sheet metal, as that would match well with the gorgeous copper-plated steel that Gottlieb used in the early days.
This page was printed from https://pinside.com/pinball/forum/topic/where-to-get-internal-leg-guard-plates and we tried optimising it for printing. Some page elements may have been deliberately hidden.
