FYI, the part # is 545-5209-06
Only place that I can find them is at Marco, but they are sold out.
http://www.marcospecialties.com/pinball-parts/545-5209-06
Maybe call them?? Good luck.
Quoted from polyacanthus:Any luck finding these?
Never found any, ended up just using clear, I tried dying them but didnt have any luck with the plastic taking in the dye, heated the water more than you normally have to and it didnt make a difference. I talked to someone more knowledgeable than me and couldn't figure anything out, not sure what kind of plastic they are made from.
Tried with 03-8247-16 instead? I'm aware its not the same numbers (yours are DE and this is Williams/Bally) but they look very similar/same. Not sure about actual measurements fit or not.
The ones mentioned above can be found in many places (not Marcos though):
https://www.free-play.se/produkter/spelplansdelar/plastdelar-poster-lampkapor-mm/plastposter/dubbel-star-post-gulyellow.html
https://www.pinballshop.nl/?subcats=Y&pcode_from_q=Y&pshort=Y&pfull=Y&pname=Y&pkeywords=Y&search_performed=Y&q=03-8247-16&dispatch=products.search
http://www.pinball.center/en/shop/pinball-parts/playfield-parts/star-posts/1714/double-star-post-yellow?c=2913
Quoted from Lhyrgoif:Tried with 03-8247-16 instead? I'm aware its not the same numbers (yours are DE and this is Williams/Bally) but they look very similar/same. Not sure about actual measurements fit or not.
Should work, i was trying to find some in the states, I didnt really want to pay $50.00 for $10.00 dollars worth. Here is mine in clear.
20180416_205530 (resized).jpghttp://www.pinball.center/en/shop/pinball-parts/playfield-parts/star-posts/1714/double-star-post-yellow
Seems to have them... (IF they are the right part).
And before you ask; they don't ship to usa. See:
https://pinside.com/pinball/forum/topic/pinballcenter-parts-needed
for possible solution.
Quoted from crlush:Should work, i was trying to find some in the states, I didnt really want to pay $50.00 for $10.00 dollars worth. Here is mine in clear.
Beautiful machine! I have mine stripped to clean right now, trying to decide whether to touch up and clearcoat or just clean and reassemble.
Quoted from polyacanthus:Beautiful machine! I have mine stripped to clean right now, trying to decide whether to touch up and clearcoat or just clean and reassemble.
Thanks, It was a fun project. I did some touch ups and spot cleared the areas with automotive clear using a sponge brush then after it dried I sanded it smooth and buffed it out. It had mylar that still looked pretty good so I just left it (read all the horror story's of pulling up artwork), all the wear was was in the non mylar areas. Had Robertstone0407 here on Pinside re powdercoat the wireforms. I was happy with the way it came out. What I liked about doing toch ups on this pin is the artwork doesnt have fine straight lines whitch made it easier for me, it almost looks like a kid did the artwork, even the lettering font was easy, you could pretty much improvise and it still looks good.
This page was printed from https://pinside.com/pinball/forum/topic/where-to-find-yellow-double-star-posts and we tried optimising it for printing. Some page elements may have been deliberately hidden.
