have dot out on my ac/dc premium dmd display. talked to chaz at kickers and he said i can replace 8x8 block on display board and part number is 112-0074-00. i cant seem to locate this part. anyone know where to find it?
That looks, Like a Stern Part Number.. Call your local Stern Distro. Otherwise Shipping Might be to high. I'm sure we could order it for you, but once again shipping to you would be killer
ok thanks. ill try playdium in toronto. out of curiosity how much would you charge to ship to n5w3p2? London ontario canada?
Try eBay
Not saying that below link is the correct one but would not be surprised of ot would work
http://www.ebay.co.uk/itm/281294333581
At least you have now something to compare original part price with
Quoted from Rensh:Try eBay
I'm Tempted to try some.
yep that looks like the part thanks! will try local stern distributor 1st
I think I read somewhere previously where someone replaced just one block and ended up with a slightly different contrast in color of the LED's so try and double/triple check with whoever you purchase from that these will be the same exact color e.t.c. otherwise you'll have one funky mis-matched color block in your display....
Quoted from fattrain:I think I read somewhere previously where someone replaced just one block and ended up with a slightly different contrast in color of the LED's so try and double/triple check with whoever you purchase from that these will be the same exact color e.t.c. otherwise you'll have one funky mis-matched color block in your display....
I ordered 10 blocks online to try.. but then I realized I don't have any junk displays to test
ok that is a good call thanks. im getting 2 blocks right from stern so hopefully they will be the same color. stern gave me the part number too so they better be
Out of curiosity does anyone know if these are common anode or cathode? What about the exact dimensions of the housing?
Quoted from prock:Out of curiosity does anyone know if these are common anode or cathode? What about the exact dimensions of the housing?
Details here: https://pinside.com/pinball/forum/topic/sterns-red-led-dmd-anyone-have-issues/page/2#post-1708231
Ebay units I purchased were not even close. I would order the Stern part.
stern is sending 2 blocks to playdium in toronto. then i will have to pay to have paydium ship them to me in london. was supposed to be in last week and no call so i will call them today.
just found this too. not sure if it would work?
http://www.pinballcenter.eu/catalog/led-dot-module-8x8-red-p-6392.html?language=english
Quoted from Shenanigander:just found this too. not sure if it would work?
They probably work, but I wouldn't count on the color to be the same. They need to be common anode 8 X 8 1.8mm modules according to Schwaggs previous post. I see a lot of 1.9mm for sale on ebay but very few 1.8mm. What are the actual dimensions of the housing?
These are 1.9mm and there are a whole bunch of these on ebay:
ebay.com link: 60 pcs Dot Matrix LED Display 1 9 mm 8x8 Red Common Anode 20x20mm 16pin
These are 1.8mm and are the ONLY ones I could find on ebay (after only a couple searches admittedly):
ebay.com link: 2x 8x8 LED dot matrix module 1 8mm CA red common anode
Quoted from prock:They probably work, but I wouldn't count on the color to be the same. They need to be common anode 8 X 8 1.8mm modules according to Schwaggs previous post. I see a lot of 1.9mm for sale on ebay but very few 1.8mm. What are the actual dimensions of the housing?
ebay.com link » 60 Pcs Dot Matrix Led Display 1 9 Mm 8x8 Red Common Anode 20x20mm 16pin
ebay.com link » 2x 8x8 Led Dot Matrix Module 1 8mm Ca Red Common Anode
Guys, I made a typo in that post (I just corrected it). They are indeed the common 1.9 mm arrays (I just checked my ebay purchase history). Sorry for the confusion!
These are the ones I bought that DO NOT match the color of the Stern modules. ebay.com link: 8 pcs Dot Matrix LED Display 1 9 mm 8x8 Red Common Anode 20x20mm 16pin
Thanks for clearing that one up Schwaggs
I suppose if you like pain you could replace ALL of the LED modules so they would match.
no prob. stern wont ship to the public i guess so have to ship to your local distributor and then pick up from there or have them ship to you. was only about $10 for a block. (i had a friend ship with his order and picked up at his place league night). so all in all a cheap fix. stern wants $150 to fix.
I bought some blocks off Ebay, but Then realized I don't have any bad displays to test them with.
I need to make sure they are 1.9 mm thought
Quoted from Gexchange:I bought some blocks off Ebay, but Then realized I don't have any bad displays to test them with.
good problem to have
I just ordered two blocks from Stern through my distributor at $7.50 each plus shipping. I'll be soldering it in myself and keeping one as a spare. .
if you have a ghost line on the dmd...look closely...one of the dots is actually out and the light is dispersing along the vertical line. change out the block with the faulty dot and you will be fixed up! this dot will not show up in display test as the test runs the dmd at full voltage (i think there are 3 different voltages the dmd runs at).
028.jpgI had pinball life order me a few of these - fixed a dead dot and a faint line like the one above. They do fit tightly, so it can be a pain in the next to get the solder out enough to have the block pop out. Easily the most difficult board work I've done. (I haven't tried SMT)
Quoted from G-P-E:Is there a manufacturer marking of any kind on the ones you got from Stern?
They do, the same as the ones on the existing dmd . I can check tomorrow if you don't have one to look at. You don't have to remove the block, just look on one side of the dmd where they all face.
Led blocks are a pain in the ass to track down data for sometimes. And domestic sources have stupid high prices. One of the few things I have to get from the ebay china route to keep affordable.
Hello i buyed led matrix on ebay it work but not same color it's brighter than original stern...is there a shop to buy exactly the same led matrix (LA-078811SE1WB) ?
Maybe this site ? http://www.ledist-opto.com/matrix.htm
Quoted from KoSLoW:Hello i buyed led matrix on ebay it work but not same color it's brighter than original stern...is there a shop to buy exactly the same led matrix (LA-078811SE1WB) ?
You have to get stern to ship to your local distributor. Then have them ship to you or pick it up.
That is a picture of the original LED blocks, in my Stern display. There are 4 blocks in that pictures.
Going to dredge this back up. Anyone have a source for these 8x8 LED blocks (where they aren't $7 each)? I need a few to repair a couple displays.
8 x 8 dot matrix LED display block 1.9 mm 8 x 8 red common cathode 20 x 20mm, 16 pin
This is what I've found so far:
https://www.jameco.com/z/LD788BS-SS22-Display-Dot-Matrix-Hi-E-Red-78-8X8-635Nm-2V-10Ma-Cc-Ar-16-Pin_2132349.html
Anyone used these?
I think the link above is wrong as the blocks are common cathode. Previous reports are that they should be common anode.
I get mine from e-bay, 50 pieces at a time, for around a buck each.
I just can never remember if they're common anode or common cathode that I use.
Quoted from HHaase:I get mine from e-bay, 50 pieces at a time, for around a buck each.
All the info I've found is that they are common cathode.
I saw comments from people saying that replacements they bought were different colors or brightness than the factory Stern displays. Are the ones you use a good match? A link to a suitable replacement would be appreciated.
I honestly don't know how they would match the stern display, I use them for a different purpose.
-Hans
Marco has these. Both blocks are red, one is not amber.
https://www.marcospecialties.com/pinball-parts/112-0073-00
https://www.marcospecialties.com/pinball-parts/112-0074-00
Quoted from ledblock:http://www.ledist-opto.com/matrix.htm
Here we can see LA-078811SE1WB and LA-078811HWB, exactly the same part number as led blocks in Stern DMD.
Quoted from Crash:Marco has these. Both blocks are red, one is not amber.
Why is one marked as amber if both are red?
Quoted from Crash:I'm not sure, I don't think Marco did their homework before listing it.
Oops! Been a while since I had to change any blocks. Arent the majority of led displays stern used red anyways?
I think all of them were red and Stern stuck to plasma for orange. I contacted a few people on these and see no evidence that Stern used orange LED blocks. The only orange/amber ones I'm aware of are from X-Pin and Vishay (though Vishay is out of their mind on pricing).
Had to fix a Ghost Busters display quick, got some of these from Jameco, they worked great.
https://www.jameco.com/webapp/wcs/stores/servlet/ProductDisplay?langId=-1&storeId=10001&catalogId=10001&productId=2132349
Quoted from pinaholic:What does it entail to install these? Much soldering?
There are 8 pins top and bottom that need to be desoldered on each block. This one only had one block bad, and luckily it was on the outside so it was simple to get under it to pop it after I removed the solder.
Quoted from Kawydud:Had to fix a Ghost Busters display quick, got some of these from Jameco
Thanks for this, I'd basically given up after several unsuccessful attempts at finding a replacement a couple years ago. I've been scavenging blocks off an donor display.
@kawydud, Thanks for posting the link to the JameCo blocks.
Did the color of the JameCo blocks match the OEM color pretty well?
Also...may I use your picture in the PinWiki?
Chris Hibler - CARGPB #31
http://ChrisHiblerPinball.com/Contact ... for board repairs
Yes, the color matched perfectly. I have fixed a few of them since I posted my original pictures. You can use the picture in PinWiki.
@kawydud, Thanks. Your pic has been cropped a bit, and appears here:
https://www.pinwiki.com/wiki/index.php?title=Stern_S.A.M._System_Repair#LED_DMD_Lights_Column_Constantly
Much appreciated.
This page was printed from https://pinside.com/pinball/forum/topic/where-to-buy-stern-dmd-8x8-block-for-acdc-display and we tried optimising it for printing. Some page elements may have been deliberately hidden.
