OK, we finally have our prototypes.
These boards are designed to work with the color DMD. They have diode protection, high brightness, wide angle LEDs, and capacitors. These features give much greater brightness and reliability than a basic LED design.
1) If the wires are soldered to the board (rather than using a connector) the back side of the board is flat with no rough edges. We'll do connectors when we get the final wood completed, as we have to put in a recess.
2) The board needs the back panel modified to accept the capacitors. We will likely move to three capacitors on shipping boards.May also need some small divots for the diodes. We'll make templates.
3) We have some seconds from previous runs of IJ backboards. These either have distorted cutouts (we provide a mask) or are cut with a recess that it is bit thin on the top side. They still need modifying.
More images here:
http://mrtn.smugmug.com/Other/2014-12-27/46597191_3LQ6Rm#!i=3788012955&k=TJ7K3f3
We'll have these up on Pinbits later, but please bear in mind that you will still need to do a little drilling and experimenting.
So to use with regular DMD:
Modify your backboard, or buy one of ours and paint it
To use with Color DMD
Request unit with soldered wires
Purchase one of our backboards (seconds only right now) and drill holes for caps
OR modify your backbox.
Our backboxes are designed for 5.25" speakers, but we do have adapter rings if you must use the original.
