I keep getting an error with switch 85 on my HS2. The manual references it but it isn't labeled on the diagram. Opt 84 works fine, but 85 is supposed to be in the same area but I don't see any other switches in that area.
I believe its further back by the lock ball mechanism. There are 3 switches in there and I think its that one. If not there then it may be one of the switches that runs under the ramp or to the far right if the ramp is up.
- This is from memory hence I do not have a definitive answer.
This is all I was able to find regarding this switch hope it may be of some help:
K2-"The left ramp entrance switch on the playfield drawing is ms-labeled
as Switch 84, it is Switch 85 according to the switch matrix chart.
My Getaway is apart for shopping, so I can't verify that. Switch 84
and 85 are controlled by the Ramp Opto Board A-13901-1."
This page was printed from https://pinside.com/pinball/forum/topic/where-is-switch-85-hs2 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
