(Topic ID: 146448)
Where gles this DH PLUG?
By robertg130
  • 8 posts
  • 4 Pinsiders participating
  • Latest reply 3 years ago by robertg130
#1 3 years ago
Hi I'm working in a DH,and I'm figuring where's optos cables and another thing goes,cause previous owner(routed)technician,decided that optos is not necessaries on pins,and eliminates a good part of it.I have this plug and don't know we're goes (maybe optos on the righ loop?
#2 3 years ago
I don't know whithout looking at mine. If no one helps you by then I can check it for you.
Mind you it could be a plug that is left un connected.
#3 3 years ago
Green and white are switch wires. Go to switch edge test and briefly short them together and see what reports on the DMD.
LTG : )™
#4 3 years ago
If the wire colors are white-orange and green-black, that would be switch # 53 "Not Used".
I'm referencing the manual from IPDB.
#5 3 years ago
Thelaw please if you can check that's will be very helpful for me
--right upper flipper don't work,selenoid fires on test.There is a pic Maybe you can see something that I didn see
-- another missing plug the big one,maybe is nothing
Thank you guys
Fixing optos that a butchered technician decided the pins don't need
#6 3 years ago
Both of those connectors DO NOT hook into anything else.
Check fliptronic board make sure everything is plugged in , and ALL fuses with a multimeter to be sure.
#7 3 years ago
Check small flipper opto board by the button. Make sure it's activating BOTH flipper optos, 1 for lower & 12 for upper flipper.
#8 3 years ago
Yes,let me check
Uptade later
$ 99.00
Pinball Sales
PinSound
$ 14.99
PinballElectronics.com
Yorktown Parts and Equip
KAHR.US Circuits
