Hey all!
Can someone provide links where I can find these parts for an Addams Family?
1.) Translite with glass
2.) New DMD (standard or colored)
3.) Remote battery
Just wanted to find some reliable stores!
Hey all!
3.) Remote battery
Quoted from Pinball-DOOD:Thank you so much! Is the NVRAM difficult to install?
It’s not hard for folks with experience doing PCB work, but the WPC CPU traces are a bit fragile so I wouldn’t recommend it if you’ve never done board work before.
Quoted from andre060:It’s not hard for folks with experience doing PCB work, but the WPC CPU traces are a bit fragile so I wouldn’t recommend it if you’ve never done board work before.
Gotcha. I’ve soldered in drivers and pre drivers before so would I be able to handle this? Haha
Most of the time the ram chip is soldered directly to the board without a socket, so you first need to carefully unsolder the ram chip, and solder in a socket. It’s a bit more fine work than a transistor so I would recommend practicing on scrap boards first. Good luck!
Quoted from andre060:Most of the time the ram chip is soldered directly to the board without a socket, so you first need to carefully unsolder the ram chip, and solder in a socket. It’s a bit more fine work than a transistor so I would recommend practicing on scrap boards first. Good luck!
Ahh, thanks. I’m going to pass on it. Is there just the battery holder with the wires? It’s not my game, so I want to be safe! I just need a link!
Quoted from Pinball-DOOD:Is there just the battery holder with the wires?
http://www.lockwhenlit.com/products.htm half way down the page. No Solder Battery Holder.
If you have the cash you might consider a repro backglass from CPR.
https://classicplayfields.com/shop/pinball-backglasses/taf-backglass/
This page was printed from https://pinside.com/pinball/forum/topic/where-can-i-find-these-af-parts and we tried optimising it for printing. Some page elements may have been deliberately hidden.
