(Topic ID: 135626)
What's the silliest mistake you've made?
By EvanDickson
  • 62 posts
  • 52 Pinsiders participating
  • Latest reply 4 years ago by TaTa
    There are 62 posts in this topic. You are on page 1 of 2.
    #1 4 years ago
    I had a string of GI out in my TOM ever since I installed LED. So I:
    1. Checked the fuses.
    2. Reseated the connectors.
    3. Examined the string for breaks / shorts.
    4. Removed each socket from under the PF, and removed the bulb - looking for a short across a socket.
    5. Traced back through other connectors.
    6. Said hmm and checked voltages at J121, which I should have done much earlier.
    7. Replaced the connector at J121. No change.
    8. Asked the ceiling WTF was wrong with my GI.
    9. Lamented that I would have to change big block connectors under the PF.
    9. Realized I never actually did #1 at all, even though I meant to start there.
    10. Did #1, and found a blown fuse.
    11. Replaced the fuse.
    12. GI is now perfect.
    Sometimes I can be absent minded.
    #2 4 years ago
    Trying to find out why a pin would boot up but not start a game, checking coin door is closed, checking ball trough then realising it just needed credits...
    14
    #3 4 years ago
    Not buying that Apple stock back in 1980.
    #4 4 years ago
    Had blowing GI fuse in a RCT and after pulling my hair out fuse after fuse checking and testing things I then realized that there was 2 more lamps on that fuse than I had thought, duh, and found a blob of solder from the bottom of a bulb in one of the lamp sockets that was shorting just enough to eventually blow the fuse.
    #5 4 years ago
    Squeezing the Charmin.
    #6 4 years ago
    Pulling the playfield too far back on a new Stern, expecting to feel a safety catch, and having it drop into the cabinet. Fortunately no damage other than some scrapes.
    #7 4 years ago
    Trying to figure out why my machine would reset when I slammed the coin door. Then I learned about the slam tilt switch.
    That just happened today.
    #8 4 years ago
    Believing in JPop.
    #9 4 years ago
    Quoted from Fulltilt:
    Believing in JPop.
    Ouch.
    #10 4 years ago
    #11 4 years ago
    Well, if that matador had spent any time in prison, that shouldn't be a problem for him.
    #12 4 years ago
    Not buying that HUO Spectrum for $600 10 years ago. I did buy the HUO Elektra sitting next to it though.
    #13 4 years ago
    2nd... behind Jpop. Buying a pin from BarryWNJ.
    #14 4 years ago
    #16 4 years ago
    First time I bought a pin myself - a Stern Dracula.
    Put the head on and didn't find the plug.. had forgotten to get it out of the cabinet
    #17 4 years ago
    Quoted from o-din:
    You really mean not buying AAPL when it was $2/ share back in 2003 (pre split so actually $14/share). It was actually twice as expensive back in 1980.
    AAPL went from $20/share in 2000 down to almost $2/share in 2003, so you might have been a little nervous during that time period.
    #18 4 years ago
    Spending hours trying to work out why my METLE sound was not working..
    I had knocked the cutout switch at the headphone jack.
    #19 4 years ago
    I bought 2 off him on ebay 3 summers ago. They were 100% as described. One (JD) did have a few dots off on the dmd. Called him. He said go buy a new one, send him receipt he will reimburse. He did exactly that. It cost $165. He did not even make me send the old dmd back to him...or even make me send photos to prove I was being truthful.
    The total pin deal was $4k delivered to my Michigan door. He wrapped and packaged these pins perfectlyl i have heard dissapointments from others though like you perhaps. Makes me always wonder why his reviews are not more consistent?
    #20 4 years ago
    Quoted from kst8cat:
    Yes I did that the other day on my AC/DC. Pulled out the playfield towards me waiting for the click, only for one side to come off the rail and fall downward. Lots of swearing, sweating and panic as finally I got it back in. I've got a scratch in the red paint of the right hand side armour, but it could have been a lot worse. I'll be extra careful next time.
    #21 4 years ago
    Leaving the stupid power cable inside the cabinet after securely bolting down a head on an early SS game.
    I'm sure most have gone thru that famous FML moment
    #22 4 years ago
    A few years back I was cleaning up a T2 and the bottle of millwax that I'd had for a few years fell and shattered spraying everywhere and leaving a noxious smell. I opened up some basement windows to air it out.
    Late that night I went downstairs pretty exhausted and tried to close the window. It wouldn't close. I put pressure on it...on the glass. I put my hand through the plate glass window and had to drive myself to the ER, shifting with my left hand so I could keep the other elevated and wrapped. I was very lucky that I didn't kill myself.
    Major lesson: don't do anything tired
    #23 4 years ago
    Brought a machine home that I had lent out, set it up, maneuvered into position between other machines, powered it on, playfield lit but game was dead, no lights in backbox. Scratched head and poked around, nothing. Got frustrated and went to bed.
    Woke up a few hours later realizing that I never connected cables to backbox.
    #24 4 years ago
    Quoted from Rando:
    I feel better now. Thanks!
    #25 4 years ago
    I gotta tell you, O-din...I'm rooting for the bull.
    #26 4 years ago
    Quoted from MarcelG:
    Just reading this gave me that "Oh god dammit" feeling in my stomach.
    #27 4 years ago
    bolting the game legs all together, bolting the head bolts in, standing there in admiration. now time to plug in, wait where is the plug? having to take the whole head off again!
    #28 4 years ago
    Thinking that I had a problem with Revenge from Mars on first startup, because I did not give the computer a chance to boot up. I turned it on, nothing, turned it off and then proceeded to check everything.
    #29 4 years ago
    pulling the plug for my display out to see if reseating would fix the flicker on my F-14 displays.
    Not realizing that at some point the key in the plug was lost.
    Plugging it back in wrong.
    Turning the machine on.
    Frying all my displays, killing them, and blowing my powers supply up as well.
    Had to buy new LED displays
    #30 4 years ago
    I take the heads off to moves games down into my basement. I moved Super Mario Bros down. Got it assembled, plugged connectors where they fit assuming each connector could only go into the correct place, turned the game on and blew some stuff up. Turns out connectors aren't unique or keyed on System 3... I then figured out that most of the connectors were labeled and if I had actually paid attention, I could have saved myself a lot of trouble.
    #31 4 years ago
    Pulled the playfield on my IM right off the support rails and dropped it into the cabinet while the game was on ...
    #32 4 years ago
    Getting sucked into Pinside drama, rumors, and gossip from know it all egos.
    #33 4 years ago
    Quoted from rai:
    yep. i was actually a developer of Macintosh software in 2001 ... most people were like "Apple is still a company?? why??" ... and then the iMac and iPod happened.
    #34 4 years ago
    trading a very nice WCS for a JVL Vortex. Very dumb decision.
    #36 4 years ago
    Quoted from rai:
    What, me nervous?
    #37 4 years ago
    Quoted from o-din:
    Selling my apple stock in 1995
    #38 4 years ago
    God there's so many pinball related things I've done wrong while shopping a machine its hard to pick. I almost always cause some sort of short in a GI string. Shorted lamps have burned up transistors on circuit boards. Dropped solder on a socket and shorted the string. Ugh. Backwards kicker switch wiring, little bits of hardware in empty lamp sockets burning when the machine is on, putting target decals on my machine, putting playfield glass on my tile kitchen floor to clean it and it exploding in my hands when it got dinged, paying 2100 for a dingy t2 when I was new to the hobby, and countless pointless drains while playing that were me just not paying attention for a second. Honestly don't regret any of these either. I almost always have to learn the hard way!
    #39 4 years ago
    Quoted from Warbound:
    Really glad to hear he might be getting a bit more honest. The pins I bought off him were at least 10-12 years ago. I bought a Tommy where every, I mean EVERY socket was rusted from water exposure and the cabinet was water damaged as well. Several parts scarfed off the machine that he never replaced. Bought a Dr. Who from him that had the cab falling apart in the front.... He counted on not being willing to send the damn things back. Really glad to hear his reputation has been making him get a bit more honest.
    His shipping was not a problem. Did a fine job there. He just wasn't honest with the condition and actual product as presented.
    #40 4 years ago
    I did this too! Scared the crap out of me. I got lucky too and didn't have any damage.
    #41 4 years ago
    Changing #44 bayonet bulbs with the power on, playfield up and high voltage engaged.
    #42 4 years ago
    BUying a Pin and getting it all wrapped up, then going "oh crap, I forgot to take the balls out". But you're so hot and sweaty, and spent so much time at the seller already you go screw it.. then you hear the balls jingle all the way home, and all you can think about is a ball getting jammed somewhere, or one of the balls bending a switch in the trough.
    #43 4 years ago
    Also my TAF kept on resetting. What I did:
    - reseat connectors
    - change connectors
    - change BR2
    - change C5
    - change voltage regulator
    - do the last resort mod on voltage regulator
    - change flipper coils diodes (all 4)
    with no results. I stopped playing it.
    One day, I can't remember why, I pulled up the game rom, but it went with my bare hands without any effor whatsoever! In the end it was this loose chip which caused the resets... *facepalm*
    One time also I replaced a whole lot of components on a JD driver board as all flashers weren't working anymore, in the end it was the connector on the coin door switch which was disconnected... sigh...
    #44 4 years ago
    biggest mistake, I hate to use the word silly. Went to change a fuse with the machine on. Was using a small screw driver to lever it out of the holder. Dropped the screw driver and somehow shorted the high voltage to the data buss, and seriously damaged three boards in the process (driver, sound, DMD), took weeks to track down and fix all the damage.
    Along the way was having a heck of time on the sound board. Just was not getting the right bongs. Took the board to test at a friends house since I did not have any other games with that vintage of sound board (wpc non-dcs), where we determined that the repair guide was wrong on the 'bong' behavior for the board with no ROMs in it (I think was the issue), and ultimately turned out I have fixed the board, but the ROMs were bad.
    #45 4 years ago
    Got hit with live 70VDC off the SAME COIL TAB three times in one night.....was trying to troubleshoot an issue and the capacitors were not discharging after the machine was off and unplugged from the wall. After the third time I started grounding the tab to the side rail with a 2 foot long flathead screwdriver any time I worked on the game.
    #46 4 years ago
    Calling a tech before checking the fuses. Ok, not bad when first learning...but then doing it again way after I knew better.
    #47 4 years ago
    pinball wise i just recently cleaned, waxed, and replaced rubbers on my Aladdin's Castle
    well long story short there quite a few star roll overs and i ended up waxing them with the playfield.
    So after the shop it wouldn't work right here i had to clean all the star roll-overs with a toothbrush.
    Don't worry I didn't use my toothbrush... my girlfriends is electric
    #48 4 years ago
    I had a very dirty unshopped WMS IJ with every pf GI bulb out. I spent a couple of hours checking voltages, connectors, triacs, fuses etc....turned out that every pf GI bulb was burnt out Lesson learned: don't overlook the obvious problem first!
    #49 4 years ago
    Pluggin in the 5v connetor to the 12V, that mistake will cost me around 3 to 4 hundred dollars. Damn
    #50 4 years ago
    changing my last name when I first got married
    $ 26.00
    Yorktown Parts and Equip
    $ 369.00
    £ 80.00
    Sillyoldelf Mods
    $ 46.00
    $ 18.00
    The MOD Couple
    Lighting - Backbox
    $ 6.00
    German-Pinball-Modular
    $ 1,000.00
    Playfields
    Pinball Playfields
    $ 7,299.00
    Flip N Out Pinball
    $ 69.95
    pinballmod
    $ 38.00
    $ 48.00
    3D MODS
    $ 1,099.00
    $ 7,299.00
    Nitro Pinball Shop
    $ 60.00
    Mods for your pinballs
    $ 249.99
    Id Rather Play Pinball
    $ 90.00
    Lighting - Under Cabinet
    $ 24.00
