There easy to remove with a security torq wrench.
What's the point?
Security is just perception.
You can smash the backglass with a rock as well.
Locks keep the bored honest people out.
Quoted from Blackbeard:There easy to remove with a security torq wrench.
What's the point?
Do you mean the torx screw in the back, or the lock on the back box glass?
I was putting in a lock last night etc and just thinking that any lock could be pulled out with the security wrench.
I can see obvious advantages in a public location... You don't want strangers opening your pin's back box and messing things up right? Or shatter the glass...
As you could imagine, if the pin companies didn't lock the glass down, people would be opening the back box to either vandalize or thinking they could somehow trigger a free game. Or even steal the translite.
Lets face it, the locks on the cash box on most arcade games are cheap junk too. You could probably pop one with a screwdriver, but if they weren't there, people would steal the cash or trigger free games.
Quoted from Blackbeard:Why would someone drill out the lock instead of just picking up the cheap torq wrench?
Few reasons...
Not everyone has the right security bits. And it's not something you can pick up everywhere. I think I had to mail order mine actually. It's not hard to get, but again, if you just got a machine home and don't have the keys or the bits, drill bit is fast and everybody has one!
But as others have said...security is definitely perception more than anything. Easy enough to smash the glass and get to the boards. Easy enough to smash playfield glass, lift up the playfield, and walk away with the cash box.
What's the point?
Who do you think you are - Seinfeld?
Quoted from NJGecko:..security is definitely perception more than anything. Easy enough to smash the glass and get to the boards. .
THis makes the most sense to me.
Someone (non pinhead) sees a lock and thinks it's all locked up.
Anyway, my shadow's head is all "locked-up" now.
once upon a time, the replay unit lived in the backbox... if it hadn't have been locked, it would have been very easy to never have to pay to play a game...
Fancy torx head screws are not on every machine lock. If I look at my late 1970's early 1980's collection of Bally pins I don't see any screw/bolt head by the lock, only the lock face. This is why I drill when I can't get into the backbox, it is the easiest thing to attack.
Quoted from NJGecko:Easy enough to smash playfield glass, lift up the playfield, and walk away with the cash box.
Um, good luck lifting the pf with the lockdown bar still in place.
The lock also keeps the back glass/speaker grill from falling out while transporting, many older games have the lock on the side of the backbox so security bits do you no good on those.
Prevent theft of the backglass or transpire itself. I imagine these would disappear pretty quick and hung on someone's wall if not. Smashing the glass to get the trans light might be an option but makes noise, causes damage to trans light, could lead to injury.
Quoted from Hobbypinball:Prevent theft of the backglass or transpire itself. I imagine these would disappear pretty quick and hung on someone's wall if not. Smashing the glass to get the trans light might be an option but makes noise, causes damage to trans light, could lead to injury.
You're missing my point. Anyone with a security wrench can just unscrew the two screws, pullout the lock, and take the backglass or boards.
Quoted from Blackbeard:You're missing my point. Anyone with a security wrench can just unscrew the two screws, pullout the lock, and take the backglass or boards.
Depends upon the game/design of the locking mechanism as not all games have security screws that hold in the backbox lock (System 11 and earlier, Sega Showcase, etc.)
And yes, it's as much perception as anything else.
Also, how many people walk into an arcade with a security bit set?
+1 to this:
Quoted from wiredoug:Locks keep the bored honest people out.
Though more likely to keep guys like us out!
Finally, security bits used to be hard to get. Now just go down to your local Harbor Freight - $10:
http://www.harborfreight.com/100-piece-security-bit-set-68457.html#.UyMUIfldX7M
viperrwk
Quoted from centerflank:The lock also keeps the back glass/speaker grill from falling out while transporting, many older games have the lock on the side of the backbox so security bits do you no good on those.
This. Also remember when transporting a game with the head folded, (not newer Sterns), to screw the inner latch for the light insert panel securely in the locked position. These can come unlatched during transport allowing the insert panel to open slightly and scratch the hell out of your backglass or translight. I just use a playfield screw to secure the latch. There will be a hole there already for the screw.
It keeps the translite/back glass in place during transit. I've had them come out if you dont lock it during transit
yes that takes time and requires someone to have a tool with them. the point is, its NOT meant to stop a determined individual with a plan. Its meant to keep honest people honest and to prevent someone acting out of impulse if it were not there.
It's most often about not being the easiest target. Why are there locks on cars for that matter? All cars have easily breakable windows right? Most car thieves actually target cars that are either already unlocked or at least very easy to unlock and to start without a key... A ton of GM vehicles from the late 80's/early 90's fall into this very category.
Quoted from viperrwk:Finally, security bits used to be hard to get. Now just go down to your local Harbor Freight - $10:
Just picked up a set for $7 at their sidewalk sale, as well as a lot of other stuff I did not realize I needed Place was crazy but there were a ton of great deals. Was like a kid in a candy shop.
What's the point of locking your front door when someone could just pick up a rock and smash the side window and walk into your house....
Looks like someone beat me to this point....
I would think the average joe burglar does not carry a security bit handy in his arsenal. I could be wrong.
I'm thinking more like a crowbar or flat head screwdriver and/or hammer.
My point: If some wants to steal something they are going to do it as quick as possible. Why F around with a security bit? To keep it clean. Pppppppleaseeeeeee!!!!!!!!!!!!!!!
I could see how on location, it would stop a 'spur of the moment' theft of a backglass, but as plenty of said, if someone wants to get inside it, they will -- just like many of us have when buying a machine missing the key.
Barrel locks are only for honest people as are most locks.
As mentioned above if they want to get in it they would. Wood and glass seems pretty easy if you had intent.
At an arcade as a child without a lock I would have likely played all day for free.
It is just to keep honest people honest it will not stop a motivated thief. IMHO.
I have been robbed on location. Luckily not much damage was done to the machines they just walked off with probably 4 bills or so. Most arcade doors were pried open or locks busted screwdriver style. The pins were safe as the keys were in a desk at that location. So they merely opened them and took the money. Due to alarm and the cops showing up on their pathetic A$$'s nothing was taken but cash. First hit was cash second hit was jail.
I know this is an old post but was wondering if anyone can confirm the size of the torx bit that is normally used. I may have a machine coming that doesn’t have a key for the back box so want to buy the correct bit prior so I can access the back box.
This page was printed from https://pinside.com/pinball/forum/topic/whats-the-point-of-backbox-locks and we tried optimising it for printing. Some page elements may have been deliberately hidden.
