This is with reference to a Williams Olympic hockey game I am restoring. See link if interested...
https://pinside.com/pinball/forum/topic/olympic-hockey-#post-4996782
Long story- short question.
I have a problem with the lights coming from the player unit. It controls if player one is lit, or which arrow is lit, and even which side of the advance rollovers light by toggling the transfer relay in a two player game. Its a typical Williams 10 position stepper (I think) and it has a total reset coil. It works perfectly mechanically. I am also highly confident it is working very well in terms of the wiper blades are aligned correctly and making strong contact at each step for each contact.
The weird part is the lights and actions it controls through the wiper blades are mostly not working in a super weird way- by gently pushing and pulling on the disc with the fingers on it I can get the lights to flicker or even stay on. Duh- would be my first response... but what I am saying is that if I manipulate the wiper disc- sometimed just gently pushing it or pulling it across the spindle- I can get the lights to flicker or even stay on but its not because the fingers suddenly made contact. The fingers make great contact. Perhaps a symptom perhaps expected- I measure 6.3 V across the wiper blades for the lights in question- to the stepper unit frame which is a ground point. I always measure voltage to ground across the fingers. They make contact- but if I wiggle the assembly and push and pull on some of the fingers I can get the lights to come on. I suspect That my wiggling is making and breaking some contact point in the assembly of the wiper or between the wiper and the grounded frame of the stepper unit.
I cannot quite figure out the schematic and reconcile it with the grounded stepper frame and the fingers on the wiper. Perhaps some of the fingers are supposed to be in contact with the frame and others not- there are insulted fingers and grounded... if the ground is intermittent would this explain my issue? How should I proceed?
