My soldering iron isn’t warm enough for the playfield ground wire work i need to do. What is the correct temperature range and solder for this?
Thanks,
R
Thanks,
R
Quoted from Robo1:My soldering iron isn’t warm enough for the playfield ground wire work i need to do. What is the correct temperature range and solder for this?
Thanks,
R
It's not so much the temperature but the capacity/wattage that matters. Ground wires will suck the heat right out of the soldering iron quickly if there is not enough wattage. Last year I purchased one of the 75w chinese knockoffs on ebay and have not looked back. Someone else might be able to chime in about the best type of solder, I use a random roll I found in the scrap bin at work.
You should get a soldering iron with temperature control, much better time soldering when the temperature doesn't drop as soon as you put it to anything. My soldering iron is a 50W Weller WES51, and it's been pretty good to mee so far. Only time I've had trouble is trying to desolder a heatsink from a Space Invaders board.
This page was printed from https://pinside.com/pinball/forum/topic/whats-the-correct-soldering-iron and we tried optimising it for printing. Some page elements may have been deliberately hidden.
