thanks in advance.
-jon
You probably don't want to substitute. It depends on the game, but the closest thing is a 11753, which is less powerful and might not work as a replacement as it could be too weak.
A 11630 would be too powerful most likely and do damage. Technically, you could put a 1n4004 or 1n4007 diode on the power wires going to the coil to drop the voltage down and make it weaker, but not recommended. I'd just get a new 11753 though. Coils are like $12-15.
FL-11753 (yellow) weakest
FL-11722 (green)
FL-11630 (red)
FL-15411 (orange)
FL-11629 (blue) strongest
LTG : )™
I think it would take a lot of diodes to sufficiently weaken a 11630 to the level of a 11722.
Best solution is to just buy the correct replacement.
If you can't, you always go one level DOWN in power (in this case, the 11753 is the only choice) and just have to accept that it may not have enough power to do the job.
ok. thanks guys.
it's an f-14 upper right flipper. coil was smoking, so I cut it out and unfortunately don't have that one on hand. the lower right flipper is now out. is that expected?
thanks. fuse is fine.
I'm wondering if the upper flipper is not connected, would it impact the lower right flipper?
Quoted from bigehrl:thanks. fuse is fine.
Does F-14 use a dual EOS switch or something for the one side?
It is the right side, so that probably has the lane change switch stacked with the EOS switch.
What about the cabinet button?
Without looking at the manual, I would say it depends on how you disconnected it. If any lug had more than one wire on it, those wires need to still be together away from the lug (and taped).
Quoted from thedefog:A 11630 would be too powerful most likely and do damage.
11630 and the word powerful shouldn't be used in the same sentence. Not a powerful coil. A littler stronger than factory, but not a plastic breaker. Most system 11's have 11630's and you don't hear a lot of complaints about air balls or broken plastics from those folks.
Quoted from phishrace:11630 and the word powerful shouldn't be used in the same sentence. Not a powerful coil. A littler stronger than factory, but not a plastic breaker. Most system 11's have 11630's and you don't hear a lot of complaints about air balls or broken plastics from those folks.
For an upper flipper? Yes, it could absolutely break plastics, depending on the game.
Quoted from thedefog:For an upper flipper? Yes, it could absolutely break plastics, depending on the game.
I upgraded the upper flipper on my location Ripley's to a 11630 a couple years ago and haven't had a broken plastic yet. I definitely wouldn't recommend an 11629 for an upper flipper. That's the big jump. 11630 (weak) ---> 11629 (much stronger).
Quoted from phishrace:I upgraded the upper flipper on my location Ripley's to a 11630 a couple years ago and haven't had a broken plastic yet. I definitely wouldn't recommend an 11629 for an upper flipper. That's the big jump. 11630 (weak) ---> 11629 (much stronger).
I guess it is really game dependent. It also changes the gameplay. I think a game like F-14 probably could get away with it, that game is a tank.
Not in a system 11 game.
There's no board control whatsoever of flippers in any system 11 game.
The only way to "smoke" a coil on a system 11 game is if the EOS switch is maladjusted and never opens.
If this happens, the power winding is always engaged, and quickly overheats.
If the current flow "welds" the cabinet flipper button contacts together during this process, it'll never release, and will continue to hold until either there's a wire failure, or the fuse blows.
This page was printed from https://pinside.com/pinball/forum/topic/whats-the-closest-substitution-for-a-fl-11722 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
