Album is here: https://plus.google.com/photos/105394408854149779428/albums/6020371358198047889?authkey=CKrUgZuJlq7-cw
Here is the breakdown...
Game is in what I'd describe as great player's condition. The DMD is bright. It is dialed in and plays 100%. I shopped it about two years ago, it probably has 100 games on it since.
I'd call it an ideal restoration candidate if you choose to go that route.
It's an off-route domestic machine. The cabinet itself is in solid shape but there is the typical leg wrinkle and a few touched up spots on the head. So new artwork and chrome side armor would put it in a totally different league.
The playfield shows some wear at the drac track. I installed the bracket to keep it from getting worse. The mosh-pit wear is covered by a Cliffy. Some insert edge lifting is visible but most hasn't broken thru the paint along the edges. The shooter lane plastic is broken at the end closest to the ball launch, as is typical. I have the Pinbits replacement for it I've just never bothered to replace it.
Boards are unhacked and all match, even the transformer sticker matches for what that's worth.
When I shopped it I re-rubbered in white, tweaked the pops, rebuilt the flippers, installed LEDs in the controlled lamps (inserts) and in addition, when I first got the machine I sent all the wireform ramps out to Rob at Zplating for a fresh refinish.
In addition to the machine, I have the following things that would allow for a full restoration:
* a hand-picked IPB playfield with an extra coat of clear
* a complete set of NOS plastics
* a complete set of hand-picked side art
This is another title that I was always going to restore however life has a way of interfering so it hasn't happened. It's a popular title so I'm hoping to pass it on to somebody that sees it as a turnkey restoration opportunity.
