So I did a thing. A packer brisket, sous vide style.
Obviously I didn’t have a great setup for this. I used an old cooler as my water bath, which worked amazingly well. I was a bit worried about my sous vide wand’s ability to hold the temp since I didn’t have a lid that would seal. No issue there. There wasn’t a good way to attach the wand to the cooler, so I resorted to a web of zip ties.
First things first, the brisket was trimmed and split into the point, and 2 portions of the flat. Then all 3 pieces were vacuum sealed.
36 hours in the water bath at 155 degrees. Then moved to an ice bath for an hour. Then removed from the vacuum bags; the juice was saved and reduced for au jus. The meat then went into the smoker for 3 hours. At hour 2, I removed the point, diced it, put it in a Pyrex dish, covered it in bbq sauce and smoked that for an hour.
All in all it was very good. I’ve had it as good by doing it only in the smoker, but it’s hard to get consistency the traditional way. The sous vide brisket is fall apart tender. The burnt ends melt in your mouth. I’d call it a win.
Also, side benefit. I don’t have to babysit the sous vide part. Set it and forget it. I topped up the water at some point, but not sure I needed to.
0F3D4020-41C6-4551-8F35-771114E2C04E (resized).jpeg6FED8967-0E1B-4BBE-BF7D-068CFAA42844 (resized).jpegDB7CD831-1D5E-4468-99EB-4A99CE2D9FE4 (resized).jpeg23FA05D8-7522-4D0B-9996-5BB76C7694B9 (resized).jpeg45E4AD03-C0A4-4191-81C2-6D63247C1E44 (resized).jpeg60775EA1-A0EC-4FEE-9459-EDF5427992EC (resized).jpeg8F21F42B-FB5C-434C-82C3-9DF56E57D17B (resized).jpeg
