(Topic ID: 305412)
What would you do?
By FLASHBALL
2 years ago
  • 12 posts
  • 6 Pinsiders participating
  • Latest reply 2 years ago by FLASHBALL
    #1 2 years ago
    Had an emergency last night. Son accidently stabbed himself with a kitchen knife. I was down in my shop working on a board.
    Long story short, I left my Hakko FR300 desoldering gun on all night by mistake and the heating element broke.
    I took it all apart to discover that one of the leads just came unsoldered. Problem is that I cant solder it back on. Apparently my Weller iron does not get hot enough to liquify the existing solder. Im assuming it must be a higher temp solder or something.
    A new heating element is $115, if Hakko even has stock. Not sure because this model is discontinued. New hakko desoldering gun is $300+
    So if you were in my situation, what would you do?
    received_310020390978202 (resized).jpegreceived_310020390978202 (resized).jpeg
    #2 2 years ago
    Hope the boy is ok.
    #3 2 years ago
    Buy or borrow a cheaper gun/iron and solder it back on. Then when your done you'll have an extra gun for back up.
    John
    #4 2 years ago
    Quoted from iamdrunker:
    Hope the boy is ok.
    He's fine. Handfull of blood and a tough lesson on how to use knives properly.
    #5 2 years ago
    Yeah, I think I'd be grateful that I didn't start a fire and toss it in the trash. Expensive lesson, but I'm glad your kid turned out ok!
    #6 2 years ago
    Quoted from yzfguy:
    Thanks. I agree. I'm very greatful for that. A friend built me a wooden stand to set my gun in during use and without that, things may have been much worse. Next purchase is a wall plug timer to auto shut off my irons.
    #7 2 years ago
    That lead looks like a thermal couple and is silver soldered to the heating element. It can be repaired but needs to be silver soldered with a torch.
    #8 2 years ago
    Quoted from yfz450:
    Thanks! My friend is going to bring me this dremel torch. Think it will work?
    received_929719137976246 (resized).jpegreceived_929719137976246 (resized).jpeg
    #9 2 years ago
    Quoted from FLASHBALL:
    Thanks! My friend is going to bring me this dremel torch. Think it will work? [quoted image]
    I doubt it.
    A few years ago, I dropped mine once and the lead broke off like on yours. No amount of heat from a soldering iron that I tried would get it to stick.
    Keep in mind that this contact point has to withstand standard soldering iron temperatures without failing.
    You might need a blowtorch or welding equipment. Since I had neither, I just bought a new heating element. Everything else on the desoldering iron was working fine, and still is.
    #10 2 years ago
    Silver Solder has a melting point of 1145 to 1650ºF. I use A Neutral Oxy Acetylene Flame to Silver Solder with. I'm not sure how hot Butane gets? Worth a try though.
    #11 2 years ago
    Called American Hakko today and it turns out they actually had a new heating element in stock for 57$ Sold!
    Went ahead and got on Amazon and bought a 30 minute wall outlet timer. Next time the timer will time out and shut it off.
    Lesson learned.
    This page was printed from https://pinside.com/pinball/forum/topic/what-would-you-do-10 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
