Quoted from 4Max:I have some Naptha, do you think that's ok to try?
Yes, that is lighter fluid.
That looks like epoxy. I don't think anything commercially available will dissolve it. It may be difficult to remove that end cap without wrecking the bar. Just to start, I'd clamp the end cap in a vise, and gently twist the bar back and forth. The cap may break loose, but you'll probably still have to get the epoxy off the bar. You'd likely have to grind it off.
Yeah, good ol' MEK. Back in the '70s, professional bowlers used to soak their polyester bowling balls in it to soften the shell. This would allow them to more easily impart a big hook on the bowling ball in competition. I didn't know it would dissolve epoxy though.
MEK will turn your lips blue. We had it at work. Caught some temps huffing it. They were a mess even after the EMT's showed up.
Quoted from Starwriter:WOW! What kind of gloves do you have to wear with that stuff?
It says on the can Butyl or PVA gloves
Nitrile will only last 5 minutes or so
Quoted from Starwriter:gloves
Always seek out the MSDS whenever in doubt!
http://eurotool.com/ftp_files/MSDS_Sheets/Attack_Solvent.pdf
See the hand protection section and don't forget eye protection.
This page was printed from https://pinside.com/pinball/forum/topic/what-will-dissolve-this-black-stuff and we tried optimising it for printing. Some page elements may have been deliberately hidden.
