Take rubber ring off. Deep well socket.
Sizes can vary, so you need to figure that out on your own.
I had a hard time finding a deep well plastic handled socket wrench that was deep enough so I drilled one of my hollow handle ones out to accommodate it and only use it specifically for these cases.
Quoted from rdrapeau3171:I purchased one of these small wrenches from Titan but can't find it. Thanks for the help everyone.
That might be too small.
I've always used a deep socket.
I bought a set of these several years ago:
TEKTON 1/4 Inch Drive Deep 6-Point Socket Set, 11-Piece (5/32-9/16 in.)
https://www.amazon.com/dp/B07RWDXCMD
I have a 4 in 1 screwdriver that happens to be the right size with no bit in it. It's not a sure bet, because I also have one that doesn't work. It's worth a shot.
Quoted from ForceFlow:That might be too small.
amazon.com link »
I agree with using a deep socket - that flat wrench he is referring to is for holding the post while unscrewing the acorn or lock nuts on top of the plastics. Additionally, there's a very good chance that the playfield could be scratched.
I like using a 6-1 screwdriver as they usually have a 1/4” and 5/16” that have a deep reach for these. The. You have a #1 and #2 Philips and two slotted sizes.
Performance Tool W975 6-in-1 Quick Change Screwdriver With Hex Torque Handle, Chrome Vanadium Steel https://a.co/d/357o26W
Quoted from dmacy:I like using a 6-1 screwdriver as they usually have a 1/4” and 5/16” that have a deep reach for these. The. You have a #1 and #2 Philips and two slotted sizes.
Ahhh yes...I had one of these with a blue handle. Of course, I can't find the darn thing. I wonder if this one would work:
https://www.harborfreight.com/6-in-1-aluminum-professional-screwdriver-set-66586.html
This page was printed from https://pinside.com/pinball/forum/topic/what-tool-do-you-use-to-screw-these-posts-in and we tried optimising it for printing. Some page elements may have been deliberately hidden.
