Going to check out and hopefully pick up a LOTR this weekend. What are the main wear spots / problems I should look for? It sounds really nice and has LED's already. Also, a shaker motor hard to install? I always see posts about people needing help.
Arwen plastic is usually always broke or missing. Make sure Balrog is working correctly. A great game good luck.
Look at the center Ring ramp, at the post on the lefthand side of the ramp entrance area, as you look at it. The factory posts were weak, and bent backwards when hit repeatedly. Sometimes, the post is bent so far back that there is damage to both the PF and the metal ramp.
Make sure your ring board works and all the LEDs on the board light up as they should. I had missed that when I purchased mine and had to send the P/D board to Clive for repair.
I seen you CL add and knew it was you since you mentioned a while back you were wanting one. Almost emailed you regarding mine but decided against it. I dunno, its been really pissing me off lately, and I just suck at it for some reason. I'd probably regret parting with it though.
Great advice guys, thank you! Always helps to hear from people who have experienced it first hand. I have played it s bit in the wild and loved it. Seems like it has long ball times, which may get tiring but I'm willing to try
It's only tiring to RGR...
Just get it JT and enjoy all that it has to offer. I personally think it is one of the best machines around; if you hate it, sell it. Easy peasy!
Quoted from pinheadpuckguy:I am not experiencing long ball times.
I rarely did?
Quoted from pinheadpuckguy:A tough, deep game.
I would add beautiful and well laid out...
Quoted from gambit3113:Look at the center Ring ramp, at the post on the lefthand side of the ramp entrance area, as you look at it. The factory posts were weak, and bent backwards when hit repeatedly. Sometimes, the post is bent so far back that there is damage to both the PF and the metal ramp.
Was this issue with the weak post resolved by the last run?
Quoted from Silverballer:gambit3113 said:Look at the center Ring ramp, at the post on the lefthand side of the ramp entrance area, as you look at it. The factory posts were weak, and bent backwards when hit repeatedly. Sometimes, the post is bent so far back that there is damage to both the PF and the metal ramp.
I don't think it was ever resolved from the factory, was it? Terry at Pinball Life has the only fix post I know of.
Quoted from Silverballer:Was this issue with the weak post resolved by the last run?
I read it on the Stern site it was fixed in 2005 and later manufacture.
This page was printed from https://pinside.com/pinball/forum/topic/what-to-look-for-when-buying-a-lotr and we tried optimising it for printing. Some page elements may have been deliberately hidden.
