Looking for suggestions!
Picked up a Sorcerer recently, and the last owner said there were major issues with the MPU. It had battery damage that was repaired, and the board was actually salvaged, as the game mostly works other than no music, sound or speech. However, there are some hacks that were done, and some parts were not repopulated as you can see in the pics below. The board is completely missing SW2 (sound check switch) and I'm not sure, but the section that is missing components looks like it has to do with a reset (??). I can't even tell the jumper configuration at W1 and W2. As far as what comes out of the speakers, it is a humming sound that fluctuates with the lights, and moving the volume knob in the cabinet, the humming does fluctuate. The sound also fluctuates when moving the speech/sound mix pot on the sound board. I've looked at numerous threads about the sound issue, but not sure if I need to repopulate and repair the current damage before diving into the sound issue anymore. I've even contacted Dumbass about buying a new System 9 board, but the wait is long. Would love to have one though. He also suggested the Rottendog MPU9211, but I'm not sure who could burn the EPROMS correctly so that the board would work in a Sorcerer.
A few things I've tried (haven't checked any voltages yet, and I don't have an oscillator):
-swapped U4 and U13 memory, game boots and plays
-pulled and re-seated associated sound roms
-pulled the board and checked for continuity on the repaired traces and they show good
-many screws were missing form the MPU and sound board, installed all screws and they are good and tight
