Making progress, albeit slowly, this weekend. Now that I'm done with the painting, I've assembled a big parts list for PBR and will divide it into two parts (due to cash flow needs) -- one for all the cabinet stuff I need, and then another for playfield stuff.
I hope to order the cabinet parts this week. Meawhile, I found some smaller things to work on this weekend, starting with cleaning metal parts with my ultrasonic cleaner and Krud Kutter, and polishing them with Mother's metal polish. I have the interior parts of the coin door I'll be buying ready to go, as well as some of the parts I mention below. I'll start working on polishing the side-rails this week.
This weekend I was able to install the metal hardware back inside the head, including the track for the door into the bottom of the head. Remember: This was an old Rack-A-Ball head, which has the slot in the wood for the slightly longer door, not the metal track. I wanted to use the metal track from the original Atlantis head I had (the termite-infested one) and also so it could have the correct door. So I used slightly longer screws that went through the holes in the metal track, spanned the gap created by the Rack-A-Ball slot, and penetrated the wood beneath it just perfect. The track holds very firmly and I tested the metal door from my Top Card wedgehead and it fits perfectly. I also installed the hasp for the lock at the top and it locks correctly too. So that door will be part of my first parts order.
I also re-attached the paper instruction cards about the patents pending, etc, and I temporarily installed the piece of wood that holds the reels, lights and mechanicals in the head (installed the brackets and everything, but later removed them) as well as the back-glass to make sure everything lines up well and fits properly. Everything looks good! I removed the mechanicals, glass and brackets later because I have not yet started working on the head mechanicals yet.
You will also notice (above) I had to drill four new holes in the bottom to align the Rack a Ball head with the holes in the repurposed Sky Jump cabinet. I am in need of two more head-bolts (the Atlantis only came with two). Any suggestions on what I should buy for those?
I also cleaned, polished and reinstalled the tilt unit (sorry, very slightly out of focus):
I'm in the process of doing the same for the Chime unit. Question on the chime unit: The plastic tub has a hole cracked in the bottom of it as shown below. Can this still be used? Will it still make the chiming sound? Can I fix this (cover with electrical tape or?) or do I need to find another tub?
