Hello all.
I was wondering what the common idea was on replacing flipper coils. Mine are still working fine, but seem a bit weak and drop down at times when a ball makes contact.
Thank you for reading this.
Hello all.
Solenoids typically do not get weaker with time. More likely your machine has either frcitional losses in the mechanism (coil sleeve, bushing, etc), excessive return spring tension, misadjusted EOS switches, or some issue that is reducing the current flow to the coil terminals.
if the coils are not shorted they are fine. money is better spent on NEW E.O.S. switches. the new switches plus properly gapped will make a huge difference
This page was printed from https://pinside.com/pinball/forum/topic/what-the-time-flipper-coil-replacement and we tried optimising it for printing. Some page elements may have been deliberately hidden.
