New! Dark mode!
(Topic ID: 92097)
What size socket is needed for SEGA ball trough switches?
By MrBellMan
6 years ago
  • 16 posts
  • 9 Pinsiders participating
  • Latest reply 6 years ago by tp
    #1 6 years ago
    I need to adjust a switch and no sockets I have are small enough. Also, where would I buy such a small socket?
    Thanks,
    Rob
    Robsgameroom.com
    #2 6 years ago
    Probably not enough torque required to where you could CAREFULLY use small pliers to undo them.
    #3 6 years ago
    Try a 3/16 or failing that a 4.5mm might do it (5 will be too big)
    don't screw 'em in too tight, the screws are quite delicate and the heads can break off easily. Learned this the hard way.
    #4 6 years ago
    I don't remember the exact size but you'll need a mini, or jewelers, nut driver set. I've never seen them sold individually, but that doesn't they're not available that way.
    http://www.globalindustrial.com/p/tools/Screwdrivers/Screwdrivers-Jewel/58-0420-5-pc-fixed-esd-safe-long-small-nut-driver-set-5-complete-drivers?infoParam.campaignId=T9F&gclid=CKKMgPyAyL4CFQVsfgodoUgAAA&gclsrc=aw.ds
    #5 6 years ago
    I'm fairly sure those are 1/8" heads.
    Chris Hibler - CARGPB #31
    http://www.Team-EM.com
    #6 6 years ago
    I believe 1/8th" is correct also.
    #7 6 years ago
    I was thinking they were 3/16, not 1/8, but I'm not 100% sure.
    #8 6 years ago
    I saved an old set of box end bicycle wrenches from long ago. They work great and have every smaller size. I just grab a few from my set and try one till it fits.
    TFTC have been replaced with Philips screws but 3/16 for RBION trough physical switches.
    This would more than cover it
    http://www.sears.com/craftsman-299-piece-ultimate-easy-read-socket-set/p-00935299000P?prdNo=1&blockNo=1&blockType=G1
    This is probably more like it
    http://www.harborfreight.com/piece-high-visibility-14-in-drive-sae-socket-set-67906.html
    Or just a basic cheap kit
    http://www.harborfreight.com/130-piece-tool-kit-with-case-69331.html
    #9 6 years ago
    The 7 piece Klein nutdriver set like Pinball Life has a 3/16 nut driver in the set, and I'm almost certain I've used the nutdriver on a set of that style trough switches....
    #10 6 years ago
    I appreciate all of the feedback. I was actually able to adjust my switch without having to unscrew the nuts. I will still keep an eye out for a watch repair style nut driver set in the future. Thank you!
    #11 6 years ago
    Upon further thought, I think it is a 3/16" head. It's the black handled nut driver in my tool box...
    #12 6 years ago
    OK, I had to go find my socket that fits. It is a 3/16" !
    #14 6 years ago
    I actually tested a 3/16th on one before I posted
    I'm only half as stupid as I seem.
    #15 6 years ago
    its actually the equivalent of around a 1mm. very hard to find. the sizes mention here are way to big. lowes has small set for around 35 bucks if you can actually locate them within the store. they look like an eyeglass screwdriver but instead have a tiny socket head that is built right on. if you have room needle nose gets them off also...in about an hour!!
    #16 6 years ago
    i havnt changed the ball trough switches, but all the other switches on my segas are around the 1mm equivalent. atleast all the ones i fixed.
    Buthamburg
    $ 199.99
    Cabinet - (Alt) Translites
    FlyLand Designs
    $ 4.49
    £ 45.00
    PinballToys
    $ 84.95
    $ 14.95
    $ 229.99
    $ 19.95
    $ 2.50
    Various Novelties
    Pinball Wheezer
    Sparky Pinball
    YouBentMyWookie
    $ 39.00
    The MOD Couple
    $ 19.95
    Various Novelties
    GC Pinball
    $ 39.00
    The MOD Couple
    $ 109.99
    PinballBulbs
    $ 22.00
    $ 5,899.00
    Classic Game Rooms
    $ 149.99
    $ 89.99
    $ 55.95
    Allteksystems
    $ 369.00
    $ 9.95
    Apparel - Unisex
    Pinball Wheezer
