(Topic ID: 116885)
what size IDC connectors?
By Kahanaohana
9 years ago
  • 12 posts
  • 8 Pinsiders participating
  • Latest reply 7 years ago by TimeBandit
  • Topic is favorited by 13 Pinsiders
#1 9 years ago
im going to change my idc connectors on my ramp opto board and a couple other boards under pf, im pretty sure its a .156 size but is it 18/156 or 22/156 gauge? I also see they come in different colors but the same size, whats the difference? im not at home to look at game and im trying to make a order, any help would be appreciated.
#2 9 years ago
Wire gets thicker, as the gauge number gets smaller.
So 18 gauge is thicker than 22 gauge.
#3 9 years ago
There are two sizes of insulation displacement connector commonly used in Bally/Williams games for board header connections: 0.156 inch and 0.100 inch. The two sizes are available in different varieties to accommodate different gauges of wire. The connector has a colored stripe to indicate the appropriate wire gauge: orange for 18 gauge, brown for 20 gauge, red for 22 gauge, black for 24 gauge, blue for 26 gauge, and green for 28 gauge.
The thicker wire on Bally/Williams games is typically 18 gauge while the thinner wire is typically 22 gauge.
The 0.100 connectors do not accept any wires larger than 22 gauge, so you can order just that single version (red stripe); the 0.156 connectors are either 22 gauge (red stripe) or 18 gauge (orange stripe) so you have to order the version appropriate for the wire used.
1 year later
#4 7 years ago
Quoted from jadziedzic:
Great info here. What I was looking for. Thanks!
#5 7 years ago
as a add-on question, where is a good place to buy wire? I'd like to find some better variety of colors, and maybe even find some two-color wire similar to what is found in our pins.
#6 7 years ago
Quoted from ninjabones:
I have bought old pinball wiring harness lots off of ebay before..........
#7 7 years ago
Bay Area Amusements sells a large variety of insulated wire (18 and 22 gauge) in the color combinations (both solid and striped) Williams used in the WPC-era games.
#8 7 years ago
thanks. exactly what I was looking for.
8 months later
#9 7 years ago
Has any one used a tool like this to do IDC .100 or .156 punchdowns (I need to redo a .100 on the connectors for the TZ Clock)?
http://www.homedepot.com/p/Commercial-Electric-Impact-Punch-Down-Tool-with-110-blade-CE70804/202039354?MERCH=REC-_-rv_gm_pip_rr-_-202039354-_-202039354-_-N
The only option I see on the pinball sites is the handtool like this one
#10 7 years ago
Quoted from Jesterfunhouse:
The tool you have linked is not suitable. Just get the one you see on the pinball sites. It is no problem at all to push in low volumes of IDC connections with a hand pusher.
#11 7 years ago
Quoted from TimeBandit:
Thanks for the advice Time Bandit!!! Much appreciated!
#12 7 years ago
Although I was just rereading your question and it may have been the sizing that you were pointing out. Yes, you need to check that you are getting the 0.100 version. Most available seem to always be the .156.
You can go directly to TE Connectivity and check model numbers etc of tools there.
$ 59.95
pinballmod
$ 1,419.00
$ 49.99
€ 160.00
Pino Pinball Mods Shop
$ 399.00
12,500 (OBO)
Las Vegas, NV
$ 85.00
$ 1,159.00
Various Novelties
Pinball Photos LLC
$ 41.99
Lee's Parts
YouBentMyWookie
$ 123.00
14,000 (OBO)
11,250 (Firm)
Trumansburg, NY
$ 69.99
$ 69.99
$ 70.00
Creekside Hideaway, LLC
€ 50.00
$ 59.95
pinballmod
2step’s shop
$ 69.99
$ 1,059.00
Pinball Photos LLC
$ 78.50
This page was printed from https://pinside.com/pinball/forum/topic/what-size-idc-connectors and we tried optimising it for printing. Some page elements may have been deliberately hidden.
