Quoted from Quench:
Strange. Earlier when you ran the jumper wire from the top metal tab of Q16 into the J5 pin 8 connector test I mentioned, you said the coil activated.
I presume the Q16 LED is now flashing indicating a short circuit failure?
For no, check the coil. Grab your multi-meter and put it on low resistance mode. With the machine Off, connect each meter lead across the drop target coil. You should get a measurement around 22 ohms.
Yes, the coil activated. The thing is, now that I think about it, you wanted me to hold the connection, put all the targets down and see if it would kick them back up.... I couldn't hold it there because the second I touched it, it reset the targets, no matter how many were down. It just instantly reset them. Kinda like its doing now, I never held the wire there long enough to see if it locked the coil but I bet it did!!
So I checked the coil its ok.
Q16 got so hot, it melted the solder on the top tab!!
I cant even turn the game on anymore to check the flashing LED's as the coil instantly locks on the Q16 gets insanely hot right away.
I did contact Alltek and I got a quick response back and they said to send them the board and they will repair or replace. So at this point, I think I'd better get that sorted out first
I will update this thread when I get the board back. If it was just replacing the TIP, I would try it myself this time but these new problems started after I repaired that through hole, so I'd better get this done right!
