On some older games that'd have hollow plungers with a spring inside them. Haven't seen it on a game this new though...
A machinist produced a part for me once and drilled out material to get the weight right. Possibility? Is it very long?
Does the hole go all the way through?
Could be to let air pass through so they can meet in the middle.
Or maybe something to do with the magnetic field so they don’t repel when they meet?
They aren’t that tight in there. I have two of these games and haven’t bothered to look. As long as they work….
I checked Cross Town and it has two solid plungers. Bally (maybe others?) used plungers with internal compression springs in the 30s and 40s but I haven't seen them in more modern games as zacaj said above. For an example of an internal spring see https://www.funwithpinball.com/resources/1939-Bally-Champion, in the Steppers section about 2/3 of the way down the page.
/Mark
I am working on an early Gottlieb machine where on the timing mechanism a push rod houses a rod extension in that cavity to provide extended reach to deploy the damper.
Quoted from brenna98:Does the hole go all the way through?
I didnt take the rod out to check but it seems to go down a good inch or so and looks to be factory fitted. Could be that it was designed to take a small spring to stop the pair from hitting each other or something when the coil energises? Odd one though.
I think there is a spring supposed to be in there to limit the shock to the doors when the plungers meet and the doors reach full open. The aluminum doors are very brittle and fail by shattering due to hitting each other when they close, this may be a shock limiting attempt when they reach full open, or slows them a tad as they reach full open to mimic an elevator door motion. Not sure if my Subway has this or not. Haven’t had to dick with it.
This page was printed from https://pinside.com/pinball/forum/topic/what-s-the-purpose-of-this- and we tried optimising it for printing. Some page elements may have been deliberately hidden.
