Quoted from Gnatty:Blackout
Head looks wrong though. maybe a head swap at some time.
Quoted from chad:Head is correct.
I own a Blackout, the head looks way too deep, look at the top in particular.
It's a Blackout. It looks like someone either used black paint at the top and bottom of the head, or the photographer blacked those areas out for some reason.
This looks like a pic from a real estate listing, they are always manipulated to make rooms look much bigger than they actually are. This also makes the objects in the room take on new shapes, like how Blackout looks longer and thinner than usual.
Quoted from gdonovan:I own a Blackout, the head looks way too deep, look at the top in particular.
Is that an optical illusion? It looks like it's partially shoved into a closet w the door removed, there's door trim directly behind the backbox and no door....
Quoted from pinzrfun:Is that an optical illusion? It looks like it's partially shoved into a closet w the door removed, there's door trim directly behind the backbox and no door....
I think you are right, I didn't notice the open doorway the pin looks to be blocking.
Quoted from pinball4ever:This looks like a pic from a real estate listing, they are always manipulated to make rooms look much bigger than they actually are. This also makes the objects in the room take on new shapes, like how Blackout looks longer and thinner than usual.
Yes I see it now, the image has been stretched out.
Quoted from gdonovan:Yes I see it now, the image has been stretched out.
It's both, image slightly stretched, and you can clearly see the angle and top opening of the doorway behind the game.
Quoted from JethroP:It's a Blackout Bowler.
shuffle disc bowler? The possibilities are intriguing.
This page was printed from https://pinside.com/pinball/forum/topic/what-pin-is-this-3 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
