(Topic ID: 173055)
What other GTB EM's used a B-8091 transformer?
By pocketscience
  • 34 posts
  • 10 Pinsiders participating
  • Latest reply 3 years ago by pinhead52
There have been 7 images uploaded to this topic. (View topic image gallery).
#1 3 years ago
The transformer in my Strange World went up in a large puff of smoke and heat on the weekend mid-way through my wife's 40th party. I've confirmed that at least one other SW in Australia has the exact same setup as mine, B-8091 with a jones plug on the motor board to select between 115 or 230VAC. So I'm wondering what other machines used this setup to aid my search for a replacement transformer...
Pic is not my B-8091... mine is as black as the inside of a large German Shepherd.
#2 3 years ago
oh dear.. you'll be needing this.
#3 3 years ago
Yeah, I figured that Doug. Any thoughts on whether I could get the ruined one rewound? I've put some feelers out to sparkys contacts.
#4 3 years ago
no thoughts sorry. hard item to find here.
#5 3 years ago
Dear pocketscience,
If it's hard to find this transformer, just buy 2 new ones, one of 240 - 24 V 360 VA and the other 240 - 6 V 200 VA
Success
#6 3 years ago
thanks for the power figures.. whats your source for them ? is it for single player games? you saved me measuring them before getting them made
#7 3 years ago
Why not install a readily available B6183 & run it through a 240-110v step down transformer.
#8 3 years ago
lol .. theres always someone who doesnt have tech ocd.
its like an electric chainsaw.. it probably works but .. it .. just .. isnt .. right..
#9 3 years ago
Bottom line: would rather keep it factory... but if all else fails I'll look at other options.
#10 3 years ago
Hi pocketscience +
What Voltage / Hertz do You have in Australia ? 220 VAC and 50 Hertz ? Or 230 VAC and 50 Hertz ? Or what ?
It is not easy to look up in Gottlieb schematics --- ipdb is not allowed to show Gottlieb paperwork. I could find in my schematics the "Spirit of 76" having an transformer "B-8091". The schematics says ("Spirit of 76") FOR US-Market: Transformer "B6183" to be used.
I say: EVERY pin beeing imported to Australia has an transformer "good to use in Australia" - to find a replacement transformer - two questions:
- DOES the "Strange World schematics" shows "stuff like an motor for a swinging target operated by 110 VAC, stuff like some Relay-Bank resetted by coils actuated by 110 VAC" ?
- DOES the "Strange World schematics" shows "an High-Tap-Lug on the 25 VAC-Side" ?
Depending on Your answers: My "Gottlieb Orbit" has an "Transformer B-10932" for 110VAC / 220 VAC most likely for "50 to 60 Hertz" - it has the possibility to have it run by 220 VAC - BUT grab 110 VAC for "(huge) Control-Bank Reset-Coil" --- and it has an "High-Tap-Solder-Lug" to make the playing "more lively" --- what do You really NEED, greetings Rolf
P.S.: In Switzerland we used to have 220VAC with 50 Hertz - nowaddays it is rather 230VAC with 50 Hertz.
#11 3 years ago
the standard is 230V 50Hz here rolf but it usually runs a bit hot and is widely called '240v'
#12 3 years ago
I just lifted the hood on my re-imported Far Out and noticed a B-8091. I dont ever envision sending this back overseas any time soon. How desperate are you? (Dallas Texas) ie I could swap it out for a regular transformer spare I have.
#13 3 years ago
PM coming your way!
#14 3 years ago
Strange World will live again, heart transplant in the works.
#15 3 years ago
Quoted from pinhead52:
he is VERY lucky to find that. they are rare state side. not sure how hard to find elsewhere.
i only had 1 in 20 yrs. and that was in a parts machine
#16 3 years ago
Ive got an OuterSpace 2p parts machine, Im guessing its a suitable replacement for the transfomer in my FO?
Or I have a DropACard bottom board parts... same transformer used between single player and multiplayer?
#17 3 years ago
far out and outer space should have the same xformer
#18 3 years ago
Quoted from boilerman:
Agreed! Mr pinhead52 is indeed one of the good guys! Strange World will indeed live again!!
#19 3 years ago
i often use the (physically) larger one from a 4 player game to replace the small single player one. works fine just doesnt sit on the same bolts.
#20 3 years ago
yea this is a 2p to a 4p, should be fine. the 230v xformer is a beast! Pocketscience will pick it up and hand carry home from LA. Cant wait to see how well it goes thru xray
#21 3 years ago
I've taken weirder things through x-ray over the years... 3D printers, playfields and backglasses come to mind..
#22 3 years ago
You're very lucky to have another matched transformer....
If I were you, I would tie up the Jones plug with cable ties or have 110v wires capped for safely.
#23 3 years ago
Quoted from Shiny_balls:
I will probably just remove all the extra stuff and just "convert" to NA 115v
#24 3 years ago
Ok here's the before I yank the 8091
#25 3 years ago
And then after. Replaced with an Outerspace transformer. 8091 was slightly larger but Gottlieb gave me the extra holes for the smaller transformer. Outerspace had a 5v tap that FarOut doesnt use.
I left the jumper block in place because the wires would be too short otherwise, Did remove the extra blue wires that would be just hanging loose.
Did power it up without any of the Jones plugs inserted and verified the voltages, all good. Plays just fine.
Now to box up the 8091 for shipment
#26 3 years ago
Hi pinhead52
in post-12 You write "... my re-imported Far Out ... B-8091" --- I wonder "HOW / WHY" Your Far Out had to travel this long distance --- nor "Far Out s" around in the USA ?
In post-24, picture I see "blue wires and an Adjustment plug" - a better view is post-25, second JPG --- we had an discussion - I show the two ways this adjustment plug can be used - "110 VAC the two primary windings mounted 'parallel' " - "220 VAC the two primary windings mounted 'in series' ": https://pinside.com/pinball/forum/topic/gottlieb-dodge-city-doingjust-weird-stuff#post-3304560 . Greetings Rolf
#27 3 years ago
Quoted from rolf_martin_062:
Hi pinhead52
Yes the FO went to France and back, I actually found a Franc in it and mounted it on the apron. I picked it up off of ebay (Houston) and put a NOS pf it it and its a very sweet game.
But yea did see the wiring and made the appropriate connections for a standard transformer thus freeing up the 8091 to ship down under to a game that needs the 240 volt primary.
#28 3 years ago
Yes the FO went to France and back, I actually frond a Franc in it and mounted it on the apron. I picked it up off of ebay (Houston) and put a NOS pf it it and its a very sweet game.
Such interesting travels for the Far Out, and very nice of you to provide a solution with the transformer swap, Ken!
#29 3 years ago
What a class act by Ken. Great "teamwork"! I'm a picky SOB and love all original parts so I admittedly can't say I would do the same, so kudos to him!
#30 3 years ago
Legend. Massive massive thank you to Ken!!
#31 3 years ago
Quoted from Otaku:
Hey GTB even provided the alt mounting holes. So its not much of a deviation.
#32 3 years ago
I've received the B-8091 transformer Ken removed from his FarOut. I'm currently in CA, and will be flying back home to Sydney to complete the second half of the transplant surgery over the weekend!
4 months later
#33 3 years ago
I never did follow up on this... the transformer from Ken is working flawlessly in my Strange World. However, it wasn't the end of the problems that I think went to cause the transformer to let go in the way it did. Two of the pop bumper coils were a mess - like the coil sleeves were melted, jamming them completely! I think one of the pop bumper switches got stuck on, and whoever was playing the game didn't realise (combo of newbie, party noise, etc) and the coils jammed on and went into meltdown, which subsequently caused the transformer to bail. All without blowing a fuse. After replacing all the coils, sleeves, stops, etc and fixing up the switches everything now plays perfectly. Thanks again Ken!
#34 3 years ago
Glad I could help...
$ 21.95
Apparel - Unisex
Pinball Wheezer
$ 9.95
Apparel - Unisex
Pinball Wheezer
$ 189.99
PinballBulbs
$ 5,999.00
Arizona Pinball
$ 229.99
$ 48.00
$ 22.00
$ 99.95
Hookedonpinball.com
$ 79.95
pinballmod
Metal-Mods
$ 9.00
$ 76.95
$ 90.00
Lighting - Under Cabinet
$ 11.00
$ 7.00
APB Enterprises
$ 248.85
PinWoofer
$ 135.00
Cabinet - (Alt) Translites
Lit Frames
$ 369.00
Filament Printing
Great American Pinball
$ 69.95
Hookedonpinball.com
