(Topic ID: 7866)
What kind of epoxy for repairing shooter lane wear?
By DrAzzy
8 years ago
  • 19 posts
  • 10 Pinsiders participating
  • Latest reply 6 years ago by rad
#1 8 years ago
My no fear has some nasty shooter lane wear, which sometimes interferes with ball launch. I've decided to take the plunge and fix the wear and install the appropriate Cliffy.
What kind of wood epoxy should I use? (that's what I'm supposed to use, right?)
Locally, I can get DAP, Minwax, and Elmers brand wood fillers - are any of those good, or should I go mail-order?
What's the recommended guide to doing that repair?
#2 8 years ago
Some wood fillers do not ever harden.
"Plastic Wood" dries very fast and sands out pretty good.
Harder than Plastic Wood (hardness probably does not matter since you are putting a Cliffy over it) is fiberglass resin used in boat repair.
#3 8 years ago
Quik Wood epoxy putty stick. Best stuff for wood EVER. Clean the wood well with magic eraser and 70% rubbing alcohol first.
Here's a link to a Cactus Canyon shooter lane I restored for a buddy (actually I restored the entire playfield but this is just the shooter portion) I didn't have to use epoxy but it will show what you need to do after that
http://crinear.smugmug.com/Pinball/Cactus-Canyon-resto/
#4 8 years ago
Quoted from vid1900:
Plastic Wood is way too soft to ever use for any pinball repair, sorry. It's for filling nail holes in furniture, cabinets and such. Fiberglass is too messy and difficult to work with. LOTS of sanding required and just nasty messy stuff. I'm sorry, not knocking your suggestions out of hand but speaking from experience. Quik Wood epoxy putty stick is THE way to go. Again I'm NOT trying to be insulting so please don't take it that way.
#5 8 years ago
I'm not insulted at all. I've used Plastic Wood many times with great success.
I've used fiberglass resin to fill divots where a ball drops continually, and because it is so much harder than wood, the divot has never reappeared. I'm experienced with fiberglass, so it is easy peasy for me.
I will try your Quick Wood Epoxy on my next repair and see how I like it. Thanks for the tip!
#6 8 years ago
Here is the product I used recently on a pin repair project, its similar to the JB product.
Worked out great, sands nice and ez to work with. "Quikwood by Polymeric Systems Inc.
http://www.polymericsystems.com/epoxies-adhesives/epoxy-putty-sticks/quikwood.htm
#7 8 years ago
Quik Wood - I'll try to scare up some of that.
At what point in the process do you use the putty? do you sand out the clear first, or use the putty, then sand out the clear and putty?
Varathane - that going to be available locally, or is that something I'll have to order?
Sandpaper - Easy.
Plunger handle - Easy.
#8 8 years ago
First, thank you, Vid
Doc you can find Quik Wood at any good hardware or big box DIY store (That's what Home Depot type stores are called in the UK
Our HD here in Cal carries Varathane as well. Use the #280001 clear gloss waterborne type.
#9 8 years ago
Local Home Despot only carries Minwax brand polyurethane spray - I assume that's not sufficient?
#10 8 years ago
i think that quick wood is the same as this check out demo -
#11 8 years ago
Quoted from jimjam:
Ha ha, nice
#12 8 years ago
Minwax is also a waterborne single part urethane like Varathane. I've used it and it's nice but for some reason I've always prefered Varathane.
#13 7 years ago
Quoted from Cliffy:
When you spray it with the new clear, and you're only doing it on the shooter lane (rest of the PF is beautiful_ - no idea why the shooter lane is in such lousy condition), how do you blend the newly clear-coated shooter lane with the rest of the PF, without there being a noticeable boundary?
#14 7 years ago
True Value Hardware carries Varathane if you have one near you.
Or you can get it from them by the individual can online here:
http://www.truevalue.com/product/Varathane-1125-oz-Aerosol-Gloss-Interior-Diamond-Polyurethane/9782.uts?keyword=varathane%20gloss
Everywhere else online you have to buy it by the case (6).
#15 7 years ago
This is the stuff I got from Lowes up here. Used it to repair TFTC before I installed the Cliffy on it. Worked great.
#16 7 years ago
How about JB Weld sanded flat under a Cliffy?
#17 7 years ago
Quoted from NM:
The JB weld for wood will work but I would not use the original grey stuff. It would really make a mess and run off asw you are trying to put it into place. The putty does not move.
1 year later
#18 6 years ago
Quoted from DrAzzy:
Good question! I've wondered the same myself. Anyone?
#19 6 years ago
Quikwood is what I used. I used a little stain to try to give it some wood grain. Finished it up with a couple coats of Varathane. Put over 2k plays on it without any chipping, etc.
PinWoofer
