Thought you were sticking to tech threads?
#75 2 days ago
TBK
xTheBlackKnightx
Pinside member
US Vancouver, WA
<1y 236 18 20
markmon said:
Yours was brought into your home when it was about 5 years old and maintained by you since. It should be in relatively good (low usage) condition. Being heavy doesn't mean better. When's last time a pinball cabinet fell apart because it didnt have thick enough wood?
Did I refer to the machine being "tank" because of weight?
I never said that.
Not all WMS/BLY widebody machines were problematic.
People need to know the "Achilles heels" and be cognisant.
STTNG? Yes, because it requires much more maintenance than others, and operators were lazy with techs, the design is fine.
TZ? Yes, some things were initially over complicated, and technicians were unskilled in some cases.
I personally did not really see any major issues, because I did my tech runs weekly.
You did not start to see the ball sensor issues until a few years, the gumball machine assembly got fixed with the added plastic tab, and the Power MPF was corrected in design from samples.
Road Show? No, turn off the $%#%ing shaker motor, to prevent issues. #1 reason for problems. Its not the "eddy boards".
Judge Dredd? Sort off, the Dead World ball locking mechanics were flawed in game design, but fixed on the final part of the run.
That was the ONLY problem with this game.
Demo Man? No, there is nothing really that goes wrong, as it its just standard opto/switch maintenance, which requires LIFTING THE PLAYFIELD, again operator laziness with sending their techs. The claw mech is not a source of problems. Nor is the lift mech for the claw. EVERYTHING is accessible.
Indiana Jones? Yes, if not checked for a LONG time. The PoA opto board and corrections are not maintenance friendly.
The locking idol is simple, the rotor lock sometimes breaks. There were parts issues with this game about 10+ years after introduction now corrected.
Corvette? Depends on opinion. Personally, I thought parts of the game were not the most well designed with the engine locks and racetrack. Engineering could have been better.
Popeye? Yes, the dual level playfield was not the best in terms of accessibility even though it was a latecomer, just not a well understood game. Parts still seem hard to come by. Just not that popular. Some people had problems with the right side spinning wheel.
Cabinet issues?
Eight Ball Champ, 1985.
(Bally-Midway)
The cabinet was COMPLETE crap made out of particle board NOT plywood, but was the right thickness.
The message I am sending here, is that there are many "old timers", and I would prefer to help, hence, I will stick the tech posts in the future.
