I am doing a restoration on an Addams Family and would like to replace this wood cabinet piece. Anyone know what it is called and where I might be able to find one?
Thanks in advance!
Thanks in advance!
It's called a hunk of wood and you make one. Easy to figure dimensions, T- Bolts go under the two holes.
It is glued and stapled in place.
LTG : )™
ummm, thanks?
I don't have a saw and a router to do a proper job so I thought someone might sell them.
Quoted from swedishc:
Hopefully someone will see this and make you one.
Same size in every Williams DMD pin.
LTG : )™
Try to contact the guys that make cabinets and see if they will sell you just that piece , Try Doug Huse . Or just go to a local woodworker and have them make one for you .Certainly would be much cheaper to make your own though .
Quoted from bjoechamp:
No relatives that are handy with woodwork?
Nope, but I might be able to bribe someone at work with beer to help if I can't find someone on pinside to help.
If not I will try and cut one with hand tools.
Just try not to cut your hands.
