Been meaning to check my shot records since I began working on this beast several weeks ago. I’ve fed it enough, that's for sure.
Quoted from undrdog:What is this razor sharp piece of rusty metal that is on the ball chute for?
Will I go to Pinball Hell if I remove it?
Should I get a tetanus shot?
[quoted image][quoted image]
As your EM Pinball MD, I strongly suggest that you not make a habit of dismantling or adding parts of machines that were designed by geniuses until further research has been approved here.
I’m taking a wild assed guess that the ball chute perhaps used to have a cover, and that piece is all that’s left of the noble clip that held the cover on. Why else would there be a big ball shaped hole in the side of the chute labeled Insert Balls Here?*
Anyone know if my guess is correct? (But I didn’t find a cover in the parts catalog.)
*I tried, but couldn’t get near close enough!
I don't know for sure what game this is on, but I'm guessing a Wms based on the font. I am wondering if the copper looking piece was supposed to be longer, and angled toward the hole? And, that a piece broke off, giving you a very sharp corner. If the piece was flexible, you would pull it back to insert a ball, and it would spring back, not allowing a ball to exit. It would also be rounded.
I looked thru my Wms catalogs from 1971 thru 1978 and did not see a piece with a hole in the side.
I'm taking it off. Probably will devalue this classic machine by ten whole cents, but its worth the hit.
Quoted from yancy:Definitely worth not taking a trip to urgent care for stitches.
Oh, now you tell me!! Just kidding... the cut wasn't that bad.
Just so folks know... the tetanus shot you got as a kid has worn off. If you haven't had one since then, check with your doc!
Us old folks get a Tdap vaccine when the grandkids start arriving... so, all good in that department!
Take that piece off and straighten it out, it’s sort of a one way spring for inserting balls. Several games on ipdb.org show that piece like Coquette
Every EM pin needs about 3 cubic centimeters of blood per year to satisfy the Relay Gods. This is the blood collection tool.
This page was printed from https://pinside.com/pinball/forum/topic/what-is-this-razor-sharp-piece-of-metal-on-the-ball-chute-for and we tried optimising it for printing. Some page elements may have been deliberately hidden.
