(Topic ID: 238906)
What is this missing post for 1977 Bally Eight Ball?
By stinkie
5 years ago
  • 15 posts
  • 6 Pinsiders participating
  • Latest reply 5 years ago by stinkie
#1 5 years ago
Can anyone identify which part I am missing? I've seen pix that make me think it's a clear post of some kind. I also saw one that showed a short red post. It goes in front of spinner. Please see photo below. I'm restoring and trying to use all of the correct/original parts. Thanks in advance!
S
#3 5 years ago
Minipost AS-2836-1, should be a 6-32 thread. - according to the manual
https://www.marcospecialties.com/pinball-parts/55-101888-02
#4 5 years ago
And make sure you use the correct T-rubber, otherwise you'll get air-balls off the post.
https://www.pinballlife.com/white-t-post-rubber.html
#5 5 years ago
Thank All. wayout440 I can't find my manual, and the download I have does not show part numbers unfortunately. Do you see the part number for the rubber? Gracias
#6 5 years ago
Quoted from stinkie:
#7 5 years ago
You can find the manual on ipdb.com. The English version playfield parts diagram has the part numbers cut off, so take a scroll through the German version. The text is German, but the diagram shows the part numbers.
#8 5 years ago
I think that post has wood screw base and uses a rubber ring not a t post rubber. Pinball resource and Marco both have em
#9 5 years ago
If there is no t-nut under the playfield then it’s a wood screw base.
#10 5 years ago
Unfortunately the German manual does not list the rubber, as the English version appears to do. I thought my manual was inside the machine, but can't find it. Thanks again!
#11 5 years ago
from http://www.pbresource.com/
#12 5 years ago
Conclusion: I think the correct part is a mini post 6-32 thread #02-4195 (see link below). But I think it is inadequate for something that takes a brutal beating, and it failed and wore out on the original playfield. So, I went with a 10-32 #530-5005-01. I only wish the stud was longer so I could have gone through the playfield and added a locknut to the bottom.
6-32 thread #02-4195 https://www.marcospecialties.com/control/keywordsearch?SEARCH_STRING=Mini+post+6-32+thread%0902-4195
10-32 stud #530-5005-01 https://www.marcospecialties.com/pinball-parts/530-5005-01
IMG_2535 (resized).JPGIMG_2535 (resized).JPGIMG_2536 (resized).JPGIMG_2536 (resized).JPG
#13 5 years ago
I pointed out the link to the correct part with the thread length that goes all the way through the playfield in my first post in your thread.
It also uses a T rubber
Quoted from Timerider:
inCollage_20190331_155914599 (resized).jpginCollage_20190331_155914599 (resized).jpg
#14 5 years ago
The original part is the T rubber one. Lots of people replace it with the more common #6, #8, #10 posts as the OP shows, however that is a preference vs. what was originally there (T rubber was hard to get for many years so people would replace the hardened ones - I think for a long time only black was available which looks horrible)
#15 5 years ago
Turns out the post I went with does go through the bottom enough for a lock-nut. Very pleased with the way it looks. Now on the next challenge(s). Thanks all!
$ 99.00
$ 44.99
Pinball Shark
$ 69.00
Pinball Pimp
$ 69.00
Pinball Pimp
2,500
Tehachapi, CA
$ 12.00
$ 119.95
Allteksystems
$ 18.95
$ 11.00
Third Coast Pinball
$ 69.00
$ 179.00
This page was printed from https://pinside.com/pinball/forum/topic/what-is-this-missing-post-for-1977-bally-eight-ball and we tried optimising it for printing. Some page elements may have been deliberately hidden.
