(Topic ID: 245489)
What is the most common problem resets Bally Skateball
By Blenderhead
1 year ago
  • 8 posts
  • 8 Pinsiders participating
  • Latest reply 1 year ago by BigAl56
#1 1 year ago
Hi group,
My Skateball has started getting random resets in the middle of a game. As the subject line says, I was wondering what the consensus is as to what is the most likely cause for this era game. Thanks for responses.
#2 1 year ago
Pinwiki has a synopsis on the MPU reset circuit:
http://www.pinwiki.com/wiki/index.php?title=Bally/Stern#Reset_Circuit
It can be as simple as your connectors not supplying a steady voltage.
There can be other uncommon reasons for a reset, but common things happen commonly. . . so start there.
#3 1 year ago
Is it happening at the same time every time? When I got my Frontier I had some fried flipper coil diodes that I replaced and the resetting cleared up.
#4 1 year ago
I had a faulty mpu once. Cold solders are another and a pain to find.
#5 1 year ago
Easiest place to start narrowing it down to me is tugging and tweaking on the mpu and solenoid board connectors and see if you can make it reset.
#6 1 year ago
Wavering 5 volts from the solenoid driver board.
#7 1 year ago
low 5v/12v. caused by bad connectors usually.
slam tilt from a switch matrix problem.
intermittent IC socket connection. gently flex on board/chips to see if it causes a reset.
#8 1 year ago
A stuck coin switch will cause random resets when the right combination of target hit and drop targets are down.
$ 9.00
$ 8.00
Third Coast Pinball
$ 50.00
€ 3.95
Multigame
$ 49.99
PinballElectronics.com
$ 9.00
Cabinet Parts
Third Coast Pinball
$ 119.95
Allteksystems
Displays
PinballSolutions.eu
