(Topic ID: 30083)
What is the best way to fix a warped plastic?
By mojozone
7 years ago
  • 36 posts
  • 24 Pinsiders participating
  • Latest reply 6 years ago by Schwaggs
    #1 7 years ago
    Would heating it with hair blower and then putting a book on top work? has anyone tried this method, and how did it go? curious about wrecking the artwork somehow.
    #2 7 years ago
    try this...
    #3 7 years ago
    Good find Marc...nice tip
    #4 7 years ago
    yea, that is awesome. exactly what i was looking for. thanks
    #5 7 years ago
    These are pictures of the huge plastics on the Hercules I restored last year. One has already been flattened but was just as bad. My advice is be patient!
    #6 7 years ago
    I dont have a air gun like the video showed, i don't know if this piece of plastic i want fixed justifies going out and getting one. Do you think a hair dryer would work, maybe take longer to heat up the area?
    #7 7 years ago
    A few more of how bad they were. They didn't come out perfect but are ten times better than what you see here. Warped plastics are very salvageable with that patience thing again.
    #8 7 years ago
    A hair dryer should work it will just take longer. The bigger the piece the harder it is to keep the heat consistent. You will learn to watch the plastic to know when it is ready to be reformed.
    #9 7 years ago
    Heat gun is good and you can see how it works in the video. If you have multiple plastics then I prefer the oven method since you can do a bunch at once. That will make the entire plastic dead flat since you are heating up the entire plastic and then flattening with weight on top and keeping the weight on it as it cools.
    #10 7 years ago
    Quoted from BoJo:
    the oven method
    I have never heard of this..is there a certain avg.temp that works best?
    #11 7 years ago
    Quoted from mojozone:
    You set the temperature to a very low setting. The plastics will soften and lay flat before the setpoint temperature is even reached, so that is why it's important to watch them the entire time and the pull once they go soft. I will have to check and see what temperature I used (it's low in the 185-225 range). Since you never reach the final temperature you want to pick something low that way it has a nice slow warm up. I use parchment paper to keep any debris from the cookie sheets from getting on my plastics. When they are done I pull them out of the oven, place another cookie sheet on top, and then add some weight (typically use four 30 packs of pop). The combo of heating the entire plastic plus using weight really does a great job. Plus you can knock out a bunch at one time.
    #12 7 years ago
    A variation on the heat gun method is to use 2 sheets of glass, place plastics on one sheet, heat them until they are soft, then place the other sheet on top, does an excellent job and is quite safe as long as you don't overheat the plastics. If you have enough direct sun, you can do this gradually outside, simply place the plastics between the sheets of glass, and let the sun do the rest!!
    Couple of old sheets of scratched playfield glass works very well for the purpose!
    #13 7 years ago
    I've used the method that dgpinball mentions and had good results. I placed the glass in the back of my pickup on the black bed liner.
    #14 7 years ago
    A high wattage hairdryer will work just fine. I wouldnt put a book on top just for the fear of any texture from the book cover transferring over to the plastic. Just pop a piece of glass out of one of your picture frames and use that, assuming its not a huge plastic.
    The only danger would come from overheating them in the oven and as long as you keep an eye on them that won't happen either. Just make sure your plastic is clean and you are using clean surfaces and don't worry - its easy and safe.
    #15 7 years ago
    Believe it or not I once sandwiched a piece of warped plastic between two pieces of weighted glass and left it in the back of my car in August. It actually came out really good.
    #16 7 years ago
    Yup i wait till its about 95 out and sandwich the plastics between two glass sheets.
    works like a charm
    --Jeff
    #17 7 years ago
    I heat them above my electric cooker. I hold them with gloves on and can feel when they are weak enough. They warp a bit more, and then they go soft. Then between two pieces off glass. It's very important to let them cool for a long time, otherwise they will warp again. About an hour or longer.
    #19 7 years ago
    In a cool oven at 80oC
    I have temperature controlled cabinets at work, easy
    #20 7 years ago
    +1 This is the method I've used for years without any problems.
    #21 7 years ago
    Quoted from PopBumperPete:
    That's 176 degrees F for the metric system impaired, like us in America...
    Chris Hibler - CARGPB #31
    http://www.Team-EM.com
    #22 7 years ago
    Quoted from starfighter:
    I've done both the 'between playfield glass' and putting them in an oven at low temps. Both worked, but between playfield glass is definitely the way to go. Patience is the key.
    #23 7 years ago
    Do any of these methods help with the spider lines that appear when a screw is tightened too far?
    #24 7 years ago
    Quoted from dasmb:
    Nope. That's a fracture line. There is no way to fix that. Ouch...
    #25 7 years ago
    I use my hair dryer and two plates of play field glass. Works great, and i don't have to worry about melting plastics in the oven. Once you have it mastered, it doesn't take that long.
    1 year later
    #26 6 years ago
    I am going to try a meythod that I used to apply to warped laserdiscs. I place it in a large ziplock bag, place bag into a bathtub full o hot water, and then place between two books. I have some throwaway plastics that I will experiment with and then report back
    #27 6 years ago
    By meythod, I meant method.
    #28 6 years ago
    Quoted from BrianZ:
    So, how long do you need to hold hairdryer above playfield glass ? I have a very warped plastic that I would like to be flat!
    #29 6 years ago
    with the hot weather here, I put two sheets of PF glass in the back of the suv with the warp plastics between them.
    let them sit all day with the windows up so it gets hot in there.
    the next morning when the suv is cooled down you can take out you perfectly flat plastics, no work or damage to your plastics
    the only downside summer is the only time this works
    #30 6 years ago
    Quoted from boilerman:
    How hot does the outside temp need to be for this to work?
    #31 6 years ago
    Quoted from dgpinball:
    this is how i do it
    #32 6 years ago
    I have tried heat gun and sunlight. They both work well. Heat gun is faster but risky. Sunlight was nothing. I have a slate counter-top in my backyard. I placed the plastics on the slate and covered them with a single piece of glass. Left them for 10 hours or so. Came back and they were perfect. Try not to think of it as a 10 hour job, it's something you get for free while doing something else.
    #33 6 years ago
    My wife has a screen printing and embroidery shop with a big heat press and that works very well. Go to your local shirt shop and they can do it in minutes.
    #34 6 years ago
    Low heat sandwiched between two pieces of glass. If it gets to hot it will melt the plastic.
    #35 6 years ago
    Quoted from Shoot_Again:
    Tried this on a big time warped plastic.
    Hairdryer with diffuser on top of the glass for 5 minutes. Then glass is very very hot. Put blanket and heavy book on top for around 4 hours. Really great result! Flat again.
    #36 6 years ago
    I flattened a couple plastics in my oven I went really slow as to not distort the plastics.
    Carefully and thoroughly cleaned the plastics with glass cleaner, then Novus 2 (optional based on how stained the plastic is), then Novus 1.
    Wife has a pizza stone which is very flat, ceramic surface. Laid down a layer of parchment paper to prevent abrasion.
    You will need another heavy item with a very flat surface. I used a cast iron pan with a very flat machined bottom.
    Preheated the oven to 150.
    Placed the plastics on the stone and parchment and in the oven.
    Monitored the plastics to get soft and pliable. This can take 20 or 30 minutes. THEY WILL NOT FLATTEN on their own at this temperature. What you are looking for is when you press on the raised part of the plastic, it bends and does not offer up much resistance. You may need to bump the temp up to 200 to get the plastic pliable. Again, the plastic will not go flat on its own at these temps.
    Once the plastic is pliable, remove from the oven, quickly place another layer of parchment paper on the top and place your heavy, flat item on the plastics while it cools. Leave the heavy item on the plastic until fully cool.
    Obviously, this requires more messing around and some special "tools" and will not work for HUGE plastics but it is another option if the other ideas in the thread above are not practical for you...
    $ 229.99
    PinballBulbs
    $ 69.99
    $ 229.99
    $ 125.00
    Id Rather Play Pinball
    $ 18.00
    Top-Notch Target Shields
    $ 38.50
    The MOD Couple
    $ 128.00
    $ 40.00
    Arcade Arts
    $ 119.99
    Cabinet - (Alt) Translites
    FlyLand Designs
    $ 10.50
    The MOD Couple
    $ 200.00
    Professor Pinball
    $ 99.99
    $ 5.00
    Metal-Mods
    $ 9.90
    Playfields
    The Super Fasteners
    $ 135.00
    Lit Frames
    $ 26.00
    The MOD Couple
    $ 89.99
    $ 54.99
    $ 175.00
    Professor Pinball
    Rubber/Silicone
    Scandinavian Pinball
