I need to replace 2 molex connectors on a WPC89 CPU. Can someone help with size and a good source to purchase some?
Quoted from gsrogers:I need to replace 2 molex connectors on a WPC89 CPU. Can someone help with size and a good source to purchase some?
Depends what you are replacing. Post pictures or something.
If you need the .156 connectors and pins to connect to the CPU headers, then look here: https://twistywristarcade.com/48-156-kk-series
If you are looking for some sort of rectangular connectors, then please post a pic.
Thanks I'll check out that link..
I need the molex housing that the wires connect to, not the pins on the board.
Garry
I can help you out with what you need. If you're unsure, feel free to shoot me a picture of the parts you are replacing and I can put together a little kit for you. Otherwise, you can check out loose connector parts here:
https://wirebot.xyz/collections/0-156
Cheers!
You sure it is a CPU board you are asking about? This where a picture is best.
J205, J212, J206-J209 are all 0.100" connectors.
J210 is 0.156".
If you are repinning connectors, very good chance the header pins on the board need to be replaced as well. Again, picture of what you are trying to replace would be great.
This page was printed from https://pinside.com/pinball/forum/topic/what-is-molex-size-for-wpc89-cpu-amp-whats-a-good-source and we tried optimising it for printing. Some page elements may have been deliberately hidden.
