What is good and safe to use on “sticking” flipper buttons?
(Topic ID: 225130)
By ezatnova
3 months ago
  • 7 posts
  • 5 Pinsiders participating
  • Latest reply 55 days ago by bzbatl
    #1 3 months ago
    Got a new AC/DC Vault Edition and installed some red/yellow changing LED flipper buttons since they look fantastic with the color theme of the machine.
    Unfortunately, they aren’t quite the quality of the OEM buttons. They sometimes “catch” or “stick”, especially if they aren’t pressed in exactly straight (ie if they are pressed at a sort of down angle).
    I’ve been contemplating what to use to fix this. I’m not sure if the inside button easily comes out of the outer ring portion, so maybe I could sand down around the sides to give it more room or smooth it out. Otherwise, I’ve hesitated to spray any kind of silicone or anything that might make it work better, out of fear for making fingers gross when playing and/or dripping down the cabinet sides, inside or outside.
    Any suggestions (other than reinstalling the OEM buttons )?
    #2 3 months ago
    They probably stick because there is already too much space between the inside button and the outer ring. The extra space is allowing the button to go in at an angle and jam so sanding it would probably only make it worse.
    I would try some gel lube that is safe for plastics. I used to use plain old Vaseline on Rubik's cubes and they would turn smooth as butter. Something like that should help without being messy. You should be able to disassemble them to get the lube inside.
    #3 3 months ago
    Vasoline will attract dust/dirt over time unless it's sealed so that might get messy. I would try a silicone spray. Works well on plastics.
    #4 3 months ago
    Thanks. Tried a minimal amount of white silicone spray. Feels a bit better off the bat...hopefully it lasts.
    #5 3 months ago
    A machine I picked up a while ago had some clear/LED flipper buttons installed that had the same problem and it annoyed the hell out of me. Thankfully, the machine also came with the original buttons, which I switched out and was much happier.
    1 month later
    #6 55 days ago
    Reporting back about a month later. The little bit of white lithium grease that I sprayed in the buttons is still doing well. 90% improvement, which is enough to not have them truly stick anymore, or really annoy me with the feel.
    #7 55 days ago
    Good tip. Have the same issue with my replacement buttons for Cyclone... will try out the lithium grease.
    $ 69.99
    $ 449.00
    $ 36.99
    Lee's Parts
    $ 50.00
    Gameroom Mods
    £ 75.00
    $ 29.99
    $ 7,499.00
    Gulf Coast Pinball, LLC
    Yorktown Parts and Equip
    $ 159.99
    $ 95.00
    $ 40.00
    $ 69.99
    $ 48.00
    Great American Pinball
    $ 69.99
    $ 239.00
    Tilttopper
    $ 27.50
    $ 445.00
    MI Pinball Refinery
    $ 20.50
    The MOD Couple
