I'd like to add some punch to the flippers on my Sys11B machine, as I suspect they're getting somewhat weaker than they should.
The flipper supply voltage drops from 72v to 63v when a flipper (anyone, not on the same time) is energised and hold. I'll expect to see a drop, but can anyone give wise words as to if this is too much. And might indicate that the powersupply is weak or connectors too loose/dirty.
Further hints to gain flipper strength is gladly accepted. The moving part is cleaned and working great. EOS switch is brushed down. The coils though, I have not replaced. I measure 0.3 to 0.5 ohm on the EOS.
