I am working on a Bally Skill Derby and I took the gear box for the forward/reverse motors apart and the gear oil was low and dirty. I cleaned everything and didn’t know what kind of oil to put back in. I asked around and someone recommended to use regular Mobil one 10W - 30. I put that in and turned the gears. There was resistance which I believe would be normal, but I don’t know how it should feel. The original oil had less resistance but it also had less oil from a leak. I then bought Mobil one 5W - 20 and that had less resistance. That is what is in the case now. I saw that Mobil had a gear oil but the viscosity was way higher. My concern on putting in a thicker oil is that the resistance would be too much for the motor and burn it out. I would like to put this machine back together but I need some advice on what oil to use. Once everything is back together, it is impossible to change the oil without taking it all apart. So the question is, what kind of oil should I use to replace the 1960 oil in my gearbox?
Thanks,
Larry.
9C9ABA1F-B46B-432F-A7F3-83B2677319E6 (resized).jpegA433A95A-059C-426E-A858-BC73730417A1 (resized).jpegBF82C6BB-6741-4FF5-91D3-8603A676C2D0 (resized).jpeg
