Toothpicks.....I swear. Get a wooden toothpick, put it in the hole and break it off. Some might need a couple.....some people put a dab of glue and the toothpicks.
Someone will have a better method, but I've used small wooden dowels with good success. Hand cut to fit flush to the top, apply a little Titebond and let it sit 'til it dries. I've found really good touch up paint at Michael's--they have a ton of enamel colors.
As foureyedcharlie said, a couple of toothpicks (or more if you need it) and some glue will take care of it.
Yes. Toothpicks.
1. Dip it in a little Elmers.
2. Insert and break off flush.
3. Repeat 1 & 2 until it's filled.
4. Tap smooth with a hammer.
5. Done.
Bamboo skewers and glue. They are thicker than toothpicks to fill the hole without gaps and will be stronger in the long run.
Well I've used toothpicks before for ensuring a loose screw slugs up nice, but I'll think about it. I'm kinda liking the wood dowel idea.
another vote for bbq skewers and wood glue but the idea is the same in all cases... glue and splinters
I'm sure toothpicks would work because I have heard enough people talk about them.
But even though they probably do... I would go with the bamboo because of better tensile strength.
For myself, I use pieces of popsicle sticks. The wood seems stronger on them than toothpick wood. The last thing you need is to put something in there... and then have the screw 'spin' again when you're tightening it up.
And if you happen to use my method... cut a piece of the stick to completely fill in the hole and then just break it (or cut it) off flush if you've cut it too long. It's not that hard to get the screw started again in the middle. Sometimes I'll use an ice pick to make a little pilot hole but usually you won't have to do this.
And maybe all popsicle sticks are not created equal??... the ones I have are fairly rigid and strong and don't need glue for strength, although I guess it wouldn't hurt if you wanted to do this too.
1/4" dowel rods do not work due to the grain of the dowel rod. The screws just don't seem to grip well. I have had good success with toothpicks, but after reading this I'm switching to bamboo. Funny thing, I was in Home Depot today looking for a 1/4" plug bit so I could cut my own plugs with the grain running across instead of with like a dowel rod.
A lot depends on the post your trying to replace. If it gets a heavy workout, toothpicks will not work. I have 3 post in my Gulfstream that just take a beating from the ball, and I am constantly fixing the post. I think I may try pintimes method with the wing nuts.
yup, toothpicks or the bamboo skewers. Dunk it in some woodglue. Stick it in the hole. let it dry and take a wire cutter and snip it off. Done and good as new.
Be sure you use wood glue. Someone commented to use Elmers which would be fine as long as it is Elmers wood glue.
By the way - that playfled looks pretty nice. Does it all look that nice?
Quoted from MikeO:Be sure you use wood glue. Someone commented to use Elmers which would be fine as long as it is Elmers wood glue.
Yeah pretty much, even though by the play meter it's nearly been to the moon already.
Quoted from Mikala:1/4" dowel rods do not work due to the grain of the dowel rod. The screws just don't seem to grip well...
Dowels do work, I've used them in guitar repair as well as plugging larger playfield holes. Toothpicks/bamboo work very well, too.
This page was printed from https://pinside.com/pinball/forum/topic/what-filler-to-use-for-blown-out-post-holes and we tried optimising it for printing. Some page elements may have been deliberately hidden.
