Just thought that working at Modern Pinball NYC is the perfect place to stress test machines as they are played almost continuously.
Things fail at an extraordinary rate so I thought I would log here what causes a machine to go down so that you can have a general idea of what it takes to run a machine on location or simply wondering what might fail on your machine. I will not post cause or repair unless asked for as it would take too long.
I will start this record from What has failed since Monday July 1 hope this helps.
ACDC Canon assembly seized Avengers LE teserac? Cube cracked.
WCS Ball motor Seized
WW Switch failed
MB Switch failed
WH20 Opto switch Failed
T2 Left Flipper Coil Shorted
WOZ Light board Failed
SS Diverter Plunger spring Broke
AF L Flipper Coil separated
Metallica Ball trough cracked
TZ Shooter Diverter coil failed , Plunger Rubber tip fell apart
Kiss Spinner switch failed
FT Upper left loop gate intermittent
Numerous stuck balls and Bulbs?Leds out.
StarTrek new Stern Left Flipper coil separated.
DM Switch Failed
