Am doing the initial check/clean of all steppers, and am baffled by one of the parts in the credit unit (Gottlieb Paradise 1965).
If I connect the spring marked in yellow, the green bit catches on the red part and it does not step down.
If I disconnect the spring and simply let part with the green end sit resting on the knocker switch, stepper steps down beautifully.
So, I could leave it, but always keen to have it setup correctly, but I'd like to know that that piece does (the bit with the green end) and am I ok to just leave it without the spring attached if the wheel seems to step up and down ok?
thanks!
