(Topic ID: 165188)
What causes a ball to jump off the playfield?
By EvanDickson
7 years ago
  • 6 posts
  • 4 Pinsiders participating
  • Latest reply 7 years ago by zacaj
#1 7 years ago
I'm finding with my Mousin' Around that the ball jumps off the playfield and ends up back in the shooter lane. A lot. Like at least once or twice per game. What would cause a ball to get airborne so often?
#2 7 years ago
what's it hitting? Standups may need new foam behind them. Make sure your flipper rubbers are on perfectly.
#3 7 years ago
Force applied to the ball in a direction away from the playfield.
Examples: a drop target that leans way back. A solid hit and the forward velocity of the ball hits the target and changes direction to upwards, smacking the glass.
A ramp transition that has a bump in it. Ball hits bump, goes airborne.
A post that isn't vertical anymore. Less likely to go airborne but still possible.
Any bump on the playfield. Raised insert?
#4 7 years ago
Anti-gravity
#5 7 years ago
Quoted from YeOldPinPlayer:
There are air bubbles under the mylar over a couple inserts, but it seems to always be off the left flipper only. Posts are all good. I'll have a closer look at drop targets for lean, and they don't have foam behind them, I'll try adding that.
Quoted from zacaj:
I'll do this too... what constitutes perfect? I usually try to get the bottom of the rubber flush with the shoulder on the flipper, is there anything else required when installing flipper rubber?
#6 7 years ago
Quoted from EvanDickson:
Yep, that's about all I know. Just make sure it actually is flush all the way around. Could have slipped or something
3,100 (OBO)
Gainesville, GA
$ 23.95
Metal-Mods
$ 12.50
RoyGBev Pinball
Gweem's Mods
Sterling, VA
$ 40.00
$ 44.99
Pinball Shark
5,000
Camarillo, CA
$ 18.95
$ 5.00
$ 45.95
$ 27.00
This page was printed from https://pinside.com/pinball/forum/topic/what-causes-a-ball-to-jump-off-the-playfield and we tried optimising it for printing. Some page elements may have been deliberately hidden.
