I just set the outlanes on my Genesis to the easier setting. I felt too many balls were draining into the outlanes due to the side bumpers hitting it right towards the outline gaps. I didn't feel it was due to player error either. The way the bumpers line up it's pointing right at the tops of the lane entrances. A lot of times, even if you don't shoot it at the mid-bumpers it catapults it straight to the outline gap to the drain. Now it seems that they never drain into the outlanes. I feel like it might be too easy now, but it's only been 2 hours since I switched it. Let's just say that the third time I played it after changing them I got the 2nd highest score I've ever reached on it.
Genesis has no ball-save feature so it's rather cruel sometimes. When the lanes were set to the larger gap, it was about a 50/50 drain ratio between the outlanes and the center drain. Now i feel like that percentage is going to sway a bit.
So where are your outlines set? Also, what's your reasoning behind the setting? Do you like an easier or harder game or is there some other reason entirely?
