New! Dark mode!
(Topic ID: 255737)
what e.m. are you working on right now?
By illawarra92
11 months ago
  • 1,310 posts
  • 187 Pinsiders participating
  • Latest reply 2 hours ago by pinzrfun
  • Topic is favorited by 39 Pinsiders
    There have been 1,102 images uploaded to this topic. (View topic image gallery).
    There are 1310 posts in this topic. You are on page 26 of 27.
    #1251 22 days ago
    Been fighting with Screamo all weekend. Now I know how it got it's name. Finally got the tic tac toe game working properly. Turns out all I had to do was losen the nut on the selection unit. Too tight and the inside and outside wipers had continuity (though they're not touching). Spent way too long tracing wires, checking switches and testing for continuity. I guess that's how you learn though. Next step is getting the game reset working properly.
    #1252 22 days ago
    Quoted from John_in_NC:
    anticipation of a new reproduction playfield from Wade Krause.
    I was at Wades shop the other day and saw the Quick/Fast Draws. They are coming along nicely.
    #1253 22 days ago
    Quoted from fattdirk:
    I was cleaning my garage yesterday
    Is your Abra Ca Dabra for sale?
    #1254 22 days ago
    Spray, you can’t brush lacquer clear over paint, it gets “hot” meaning it melts the prior coat. It’ll smear (I know I wrecked a really nice el dorado learning)
    so how are you doing this brushable lacquer. once your touchups are done, then what?
    #1255 22 days ago
    Quoted from boilerman:
    Not brushing lacquer, lacquer sprayed over lacquer (original clear) will melt original clear and if brushed, will smear original art and touch ups paint on and around original lacquer.
    #1256 21 days ago
    Here's one of my reset problems. 65 years of wear.
    #1257 20 days ago
    Finishing up a WMS Toledo for a client. Steve Young at PBR had these caps stamped with the '10' on his offerings (Bally text, but who's complainin')!!! Just glad to be able to replace the crispy originals. With two big relay banks and a boatload of other mechs, the playfield is one of the heaviest I've worked on (Solids N Stripes probably takes the prize). In my opinion, it's a tad shy of a dud, not one of Harry Williams better games by a long shot. I always wondered who thought up the ridiculous theme of this game... but there's so much more to complain about, my biggest beef being the upper flippers. Using them to hit the buttons to advance the 1 through 8 feature is sure to drain your ball on the opposite outlane pronto. In other words, upper flips totally useless. Not quite a complete snooze fest, but it's close.
    #1258 20 days ago
    I’ll put a big flat washer stack under the wire ball guide, alternately prying each end. Twist a large flat head screwdriver between the top washer and wire. Watch the playfield does not pull up with the wire.
    If I do the touch ups before removing the wire form ball guides, do I risk messing up the touch ups when I am trying to pry up and out the guides?
    #1259 20 days ago
    Quoted from tyking:
    Any work around touch ups can be a risk I guess, you should completely strip and clean the surface before touch ups.
    #1260 19 days ago
    Waxing a triple action playfield. Did some adjusting of switches and a major contact cleaning spree. Now every light and switch/target works as it should. Found a couple of broken solder connections thrown in the mix for a bit of extra fun.
    What a difference a good wax can make.
    The mother of invention stepped in the lend a hand as well. I had to make a tool as I didn't order one when I ordered parts.
    IMG_20200930_170726621 (resized).jpgIMG_20200930_172359831 (resized).jpgIMG_20200930_172557198 (resized).jpgIMG_20200930_172602572 (resized).jpg
    11
    #1261 19 days ago
    Before & after. I'm very happy with how the wood rails look now.
    120236385_332771898009221_2383872701531687990_n (resized).jpg120473534_4476772472364788_1721594143285498898_n (resized).jpg
    #1262 18 days ago
    Quoted from PinballFever:
    [quoted image][quoted image]
    Is that with a magic eraser and naphtha?
    #1263 18 days ago
    This project is getting the extreme kids gloves treatment. I finally gathered myself enough to take a ball guide out. I went with the adjustable pliers method, I saw in this video:
    It just seemed the most simple. I used a microfiber cloth between the pliers and playfield and the wire. I only pulled out a little wood on the first one I tried. The rest should be a breeze. After the clear coat do they just get tapped back in, or is it supposed to be done with a glue or something else too?
    #1264 17 days ago
    Quoted from tyking:
    You only have to per-drill the clearcoat out of the hole. Use same size bit as the wire the barbs will hold it in.
    #1265 17 days ago
    Double post
    #1266 17 days ago
    Quoted from tyking:
    I cleaned the dirt and old lacquer off with lacquer thinner then gave it 3 thin coats of shellac, sanding lightly after the first 2 coats.
    This is what the wood looked like after I cleaned it with lacquer thinner before applying the shellac. I was planning to reflow the lacquer but a lot of the old lacquer was worn off.
    #1267 17 days ago
    This afternoon I have to get organized and make a “good machine” and “bad machine out of these two captains. The good one will get cleaned up with some new parts etc and the bad one will get attacked with stuff from CPR.
    #1268 17 days ago
    A customer's game is cleaning up nicely. There are good and bad points to shopping a Bally of this era. The main relay board was pretty easy to go through since you can swing it up and forward to service it without removing it from the game. The top arch was a total pain in the ass puzzle to reassemble including one pair of wires through the arch and playfield for a switch as the top right gate. Cleaned up well though.
    #1269 16 days ago
    Just wrapping up this one. Funny, I have not seen many in BC, Canada. It's a really neat game, was a treat to have a nice base to work from.
    #1270 16 days ago
    I would like to add that title to my collection some day. The quality buxom artwork gets 2 thumbs up.
    #1271 13 days ago
    Still have a little more GTB em stuff to work on but this will be my project for November.
    #1272 9 days ago
    Waiting on the clear to dry to finish leveling and sanding for cowpoke. Stripped my quick draw cabinet to start restore in anticipation of a new reproduction playfield from Wade Krause.
    I may be developing late stage A.D.D. Tore into my Fast Draw as well as my Quick Draw. The FD cab was a wreck. The head and body had MDF in the bottom of the head and back side of cabinet. They stood on a wet seaside shed in Boston
    9C8BE437-71FC-4954-9A2F-4BCF5A523E96 (resized).jpegCABBAF66-A1BA-49FC-AB46-A68112B9C00D (resized).jpeg5547474F-7F4B-49F4-93FA-6B860C9C458B (resized).jpeg8735A951-D65D-4736-BD78-C6950AC02D87 (resized).jpeg8BE78C4B-F489-4388-94EC-3837107962C1 (resized).jpeg94C66EA5-87A9-4217-991A-D547DB5A5041 (resized).jpegC4B77949-50EF-4214-B02A-CF438F401412 (resized).jpeg1F44D634-B2DD-4278-B514-43A20B2A7F95 (resized).jpegD20C8C04-81AF-4F74-B380-114FB451E296 (resized).jpeg
    #1273 8 days ago
    I figured out a way to get the massive OXO relay bank out of the way while working under the playfield.
    #1274 8 days ago
    Started taking the playfield plastics off this Super Spin. I have never worked on a vari-target before so I’m looking forward to that. Backglass is in great shape. Cabinet is good. PF and inserts do need some work as do the pops.
    Some of the scoring switches are not registering, but where is the fun if everything works?
    Alberto
    268BAAB1-B69D-48AE-9959-43D35FB2C196 (resized).jpeg382D1837-895D-4A01-A64E-4A3ED2F96E91 (resized).jpeg699646DC-A272-4AAE-8751-DC4D85FD937B (resized).jpeg
    #1275 8 days ago
    Working on a 1962 Williams machine. The back box has 8 steppers that I am in the process of breaking down. (Not fun) One has a smoked coil and plunger.
    #1276 8 days ago
    Quoted from Playdium:
    What is this mysterious machine? Don't keep us in suspense! Arcade game?
    #1277 8 days ago
    It has to be a Pitch and Bat. He has World Series listed in his collection. That has to be it.
    #1278 7 days ago
    Quoted from stashyboy:
    Williams 1962 World Series. Restoration progress shown in Arcade section.
    #1279 7 days ago
    Quoted from EJS:
    I’ve been looking for one for quite some time- and you have two! November looks good for you!
    #1280 7 days ago
    Quoted from Nikrox2:
    Once my playfield swap is done I’ll be selling the one with the better original playfield if you are looking for a road trip. Haven’t decided if I’ll sell unshopped or not. They are both working 100% right now.
    #1281 7 days ago
    Target pool almost done. Need new flipper bats for sure.
    #1282 7 days ago
    Will be starting work on a Stoner Super-Zeta soon. Can't find much info on it, so I'll be documenting as I go.
    #1283 6 days ago
    Quoted from EJS:
    What a great pin, you should check out the Pinburg quarterfinals video linked to its page in Pinside, which I just Found thanks to your post.
    #1284 5 days ago
    Continue to work on my Wizard. I have finished all the work on the lightboard which included disassembly of all the reels and relays and steppers and cleaning and adjusting
    Today started on the lightboard. First job is cleaning and adjusting the motor switches. Not a bad job on a Bally motor. Remove them all then start at one end. You can turn the discs by hand and easily check all the switches.
    Cab is painted and stenciling will start soon.
    #1285 5 days ago
    Some after photos of Williams Wild Card. Really cleaned up nicely.
    1AAD8549-3EE3-4C97-80BE-8DD915A0C061 (resized).jpeg66A3DD9D-33B9-4FCF-BB66-A090695D7688 (resized).jpeg7CF00B40-C699-45D8-9B6B-4722843899F5 (resized).jpegE956C552-49D6-411C-835E-8F94BC7500CC (resized).jpeg
    #1286 5 days ago
    Working on a WMS OXO right now. Lots of corrosion, but everything except some light bulbs worked before stripping and pulling the playfield out. So many light sockets to clean/replace. Hopefully it all goes back together and everything works.
    13A4E066-2397-4BEF-802D-CF14D38F5C09 (resized).jpegA03045DE-8518-48BF-B503-640081CC18B6 (resized).jpegA7CAE27A-7B92-4EEF-A034-EAF802415818 (resized).jpeg
    #1287 5 days ago
    Quoted from atpcfiaim:
    Wow that looks just like a WMS World Cup they must have dug out these playfield drawings to design it.
    #1288 4 days ago
    Delivered Toledo today to a great family in Virginia... Dave, Sarah and their two daughters were incredibly stoked to have their game back after so long. Sarah was already playing when I walked out their front door, putting a big smile on my face. She was given this game on her 10th birthday by her uncle, who is still the owner of Victory Glass, a long-revered glass globe provider to the jukebox market. Also attaching a few pix of their prized Wurlitzers, all of them were in incredible condition. Beautiful day to be out and about, couldn't have been better weather to enjoy the occasion.Resized_20201015_142635[9332] (resized).jpegResized_20201015_140736[9336] (resized).jpegResized_20201015_181654[9340] (resized).jpegResized_20201015_182032[9335] (resized).jpeg
    #1289 4 days ago
    Working on a 1958 Satellite that may never had seen a cleaning on the Playfield or new pinballs. The balls had flat facets all over them. I had never seen that before. Lots of touch ups in order, but I love the theme and artwork so will soldier on. Before and after a deep cleaning.
    #1290 4 days ago
    Just finished my project tonight.D7C7B768-CD0F-4FF5-B33E-3878A81F803B (resized).jpeg
    3B1E0F78-979B-4C8E-B2D2-349FF181FF91 (resized).jpeg8478B4EA-7C53-43DE-985B-5828E0F6D898 (resized).jpeg93FCDED6-B383-4C94-8609-DA75A941EE30 (resized).jpeg
    #1291 4 days ago
    Target pool done for now. Have some contacts that need cleaning but I’ll get to that later. Going to take a break this weekend and start Card Whiz Sunday night.
    7ECEDB4D-1B9D-47E0-AC1E-380911A969D9 (resized).jpeg94F32ED6-B098-4E4F-9489-A8DD22A100AF (resized).jpeg
    12
    #1292 3 days ago
    Finished cowpoke complete restore. Needs debugging. I have about 160 hours in it.
    Need schematics if anyone has it’d be great to get a high resolution picture
    9E9450F1-9FE4-4048-BDE1-814C14709D7D (resized).jpegDD801DD4-3DD0-48E5-B2B8-F61DBB47DF3A (resized).jpeg
    #1293 3 days ago
    OXO finally cleared of all hardware for work on the playfield.
    #1294 2 days ago
    Amazing work on the Cow Poke! (May have the schematics. If so I’ll pm)
    #1295 18 hours ago
    Nice work.
    #1296 18 hours ago
    Making progress on Jive Time, pretty much "touching up" every inch of play field. Hit most of the colors right on, but could never quite get the yellow right. Going to mylar entire playfield when done. Since touch ups aren't exactly perfect, mylar over waxed play field, instead of clear coat, would give someone down the road a chance to improve on my work.
    2020-09-13 18.25.15 (resized).jpgIMG_7212[1] (resized).JPGIMG_7216[1] (resized).JPG
    #1297 16 hours ago
    Quoted from DCRand:
    I think you did a fine job! It's incredibly tough touching up areas that have serious swirl, without airbrushing the entire color. Not much fun doing planking touch ups either, kudos!
    #1298 16 hours ago
    First time denuding a playfield. Still can’t seem to figure out how to get the pop bumper off though (see photo from under playfield). I figure the roll overs I can just pin down with some little pieces of cardboard underneath the playfield when the clear coat goes on.
    Any tips on touch up technique would be appreciated. I have the acrylic paint pen thing coming this week. Any guidance on “planking touch ups”? I recall someone posting something about doing pin tip touch ups. Is that a thing too?
    0C49FED3-CC1B-4523-A6FB-88BC702AC3FD (resized).jpeg2B78AAA7-0F5A-48AE-BD9A-34E4A19E60A1 (resized).jpeg38145B8B-15AE-4473-9C7C-9BA7EC8F5B8B (resized).jpeg3DBB3C86-8D3B-404D-BD10-FA1BFED592ED (resized).jpeg6ED86BF8-0583-4D16-AA0B-FE1A9A7AB70F (resized).jpeg97AF6097-2618-4D13-85DA-D0B41C87F84E (resized).jpeg
    #1299 16 hours ago
    Quoted from tyking:
    [quoted image][quoted image][quoted image][quoted image][quoted image][quoted image]
    Pop bumpers need to have the lamp leads de-soldered to remove the assembly.
    #1300 15 hours ago
    That’s above the playfield right? How do I access them?
    $ 42.00
    The MOD Couple
    Metal-Mods
    £ 99.00
    Creo Pinball
    $ 45.95
    Hookedonpinball.com
    $ 149.99
    $ 139.00
    Sparky Pinball
    $ 369.00
    $ 149.99
    $ 69.99
    $ 60.00
    Docquest Pinball Mods
    $ 6,295.00
    The Pinball Place
    $ 55.00
    $ 7,999.00
    Little Shop Of Games
    CzTV Mods
    $ 55.00
    Various Novelties
    Pinball Photos
    € 159.00
    FlipperLED
    Pinball Pro
    $ 29.99
    $ 130.00
    Playfield - Plastics
    Special When Lit
    $ 36.00
    bB Customs
    $ 5.00
    3D Tech. Pinball Parts
    $ 137.00
    $ 9.95
