Quoted from loren3233:Plastics
Eh, there's probably some sort of plastic in there but nope...
Quoted from EJS:PlayStation 3 motherboard due to thermal sensor desoldering itself.
So close. It was my TV main board. Still dead though. I’m looking at the boards with a thermal imager. All boards have power but I’ve got no sound, backlight nothing. I suspect it is a surface mount cap gone bad. This TVhas more boards than any TV I’ve ever owned.
Ok, help a total greenhorn like me understand what your trying to do with the oven. I’m assuming trying to melt the solder a little so it reflows a little and makes connections?
Quoted from JayDee:Ok, help a total greenhorn like me understand what your trying to do with the oven. I’m assuming trying to melt the solder a little so it reflows a little and makes connections?
Remove all the components from the board. Heat it up. Shake them off.
Quoted from LTG:Remove all the components from the board. Heat it up. Shake them off.
Ahh, that makes more sense. Thanks. I’m a little less green now
