(Topic ID: 216373)
Wh2o lighting issue
By Dantesmark
1 year ago
  • 5 posts
  • 3 Pinsiders participating
  • Latest reply 1 year ago by robertg130
#1 1 year ago
Hi guys! I have an issue on my whitewater...
The inserts to the left that spell r-i-v-e-r, the last (r) is not working correctly. The led looked like it was out, so i swapped it w another and screwd it in and presto it works... but then i took my hand off of the led and it stops lighting. I have tried multiple bulbs and swapped out the twist outled that holds the led, but it still may only light for a few seconds then shut off again...?
Ive also adjusted the side prongs and sand the contact points on the socket and entry hole on the board.
Best i can gather is it is a problem on the board since swapping the outlet and leds elsewhere they work.
Problem 2-
The #6 raft led is a lot dimmer than all the others. And yes i have swapped bulbs on that one too.
Any guidence would be great?
#2 1 year ago
Happens yesterday to me(R),I used some solder in the light board to refresh contact.Work fine now
#3 1 year ago
So just like a drop on each contact point?
#4 1 year ago
Yes just a reflow of solder not a whole lot
#5 1 year ago
Not a drop,is like reflow solder,also light sand the bulb contact legs(plastic socket)
If this not work check if the trace on the light board is ok
$ 229.99
$ 47.00
$ 99.00
Pinball Sales
