My WH2O upper playfield G I has been out for a while. Constantly blowing F10 . So i did a search and found someone who was having similar problems, gi in general... They pulled the board and checked the traces on the board itself for continuity. I had checked wire continuity before but never thought to check the traces.
I spent the next 15 min labeling and taking pictures, and pulled the board. All traces checked out. However, whoever put this board in originally did a poor job. The fourth pin from the right on J120 was bent down. I panicked thinking i had caused this during removal. It turns out that pin is not used. And the connector is plugged in that location. More on this later. I checked all traces associated to GI and it had good continuity.
I plugged everything back in anticipating a long day of broken wire hunting . Plugged in a new fuse, turned it on to watch the fuse turn bright outrage and finally give out, and it didn't blow.. Woohoo. GI was on .
Now am exited and start playing, haven't had upper gi like ... ever!
Last night F10 starts blowing on a regular basis. new fuse, power on, pop.
Is it the bent J120 pin .. Maybe causing a loose our not so great connection that it is shorting? How can i remove that pin? Can I just snip it with some small dykes? If that doors not solve it what's the next plan of attack i should take?
