Would what I have pictured from Pinball Life work for replacing the upper right flipper in my WH2O?
If I'm reading the manual right it should technically have a different crank link assembly, flipper crank assembly and a different spring.
It will. However if you are only upgrading to the newer style return spring, why bother buying the entire assembly?
More habit than anything. When I get a game typically one of the first things I do is put in new flipper assemblies.
I really like the snappy feel of them. Mike Chesnut was a big believer in doing this and first got me in the habit. Then, in a home environment, I typically don't have to mess with them again.
@rockytop,
My WH2O has the same setup as pictured. Just be mindful of the following when you assemble it:
https://pinside.com/pinball/forum/topic/reason-for-wrong-flipper-parts-on-wh20#post-2600607
Quoted from Gorgonzola:rockytop,
Thanks for the heads up on that.
Quoted from yzfguy:Let terry know what it is for. He will take care of ya
Agreed. Terry is awesome.
This page was printed from https://pinside.com/pinball/forum/topic/wh20-upper-right-flipper and we tried optimising it for printing. Some page elements may have been deliberately hidden.
