(Topic ID: 115025)
wh20 switch problem
By rtgran
5 years ago
  • 8 posts
  • 5 Pinsiders participating
  • Latest reply 5 years ago by rtgran
#1 5 years ago
Having a problem with machine awarding credit when hitting spine chiller ramp - it looks like switch 46 at the bottom of the ramp works correctly (get wave noise when it hits) but the credit doesn't get awarded even if the ball goes all the way around the ramp - i think, from the manual, there may be an opto switch up higher i need to look at?
#2 5 years ago
There is a switch on the ramp under the mountains that may need adjusting.
#3 5 years ago
Quoted from fiberdude120:
Thanks for the tip. A couple more questions regarding the same machine:
When I hit Disaster Drop, the animation plays for a ball lock, but does not award one. Any idea what that is all about? Not really a huge deal, but when it thinks a ball has been locked it tries to plunge... nothing.
The first and most prominent problem we had was the ball getting stuck when being fed to upper right flipper. It seemed to be getting stuck between the plastic and wood of the upper playfield, right after being plunged from No Way Out.
Thanks for the help!
#4 5 years ago
Any switch errors in the status report?
Go into switch test and load balls one at a time into the trough to verify that those are working. Load balls one at a time into No Way Out to see if those switches are all working. Use a ball to test the switches through the Spine Chiller to verify that nothing weird is happening (multiple switch closures).
The ball getting stuck after being ejected to the upper playfield is likely caused by a divot in the playfield where the ball hammers into it. I have the same problem on mine. I bought the Cliffy protector to resolve the problem, and will install it when I reassemble my game.
http://www.passionforpinball.com/wh20.htm
#5 5 years ago
Quoted from mot:
I like the idea of the Cliffy protector, although it seems that the ball also gets stuck on the plastic part of the ramp, almost on the lower screw. I assume that just tightening those screws as much as possible will help that. Any tips one the best way to get to those screws without taking too much apart?
#6 5 years ago
Quoted from RudyGranaghan:
That sounds like what mine was doing when I had that switch problem that I said to check. Check the switch first and see if the problem goes away.
#7 5 years ago
is its getting caught where the wood and plastic meet? With new ramps in mine there is a bit of a gap and I can get balls stuck there, I just need to mylar bridge the gap, I just have not done it yet.
#8 5 years ago
thx for the replies guys- my son got on and took over some of the thread - just got this machine a couple of months back and just learning about it - didn't even realize there was an opto up there - then it wasn't working so thought i was going to have to order a new one - then figured out and second switch was "out" and know those optical switches are fairly reliable - so switched the connections and voila, everything works! seems like when it was refurbed someone switched the two connectors
still have the problem with ball getting stuck - probably going to have to remove upper playfield to try to get some incline on the ramp
$ 50.00
$ 54.99
$ 9.95
$ 48.00
$ 369.00
