Quoted from Hougie:Shorted diode, socket, or lug should take out a transistor first, shouldn't it? That's the part I don't get. So if I test the associated ULN2803, 74LS374, and LM339's. Which legs should I test with my probe?
Thanks for the help guys. I'll also look into the wiring today.
It depends on what is shorted to what. There's a lot of possibilities. In the case of a row transistor, a short to ground wouldn't blow up anything, but a short to coil 50V would.
U10-8 would be the most telling. If that's transitioning, but row 8 is locked on, it's almost certainly a dead TIP102 or a playfield wiring short.
Quoted from thedefog:If a diode is shorted, then it is completing the ground path, bypassing the TIP102's job. That wouldn't kill the transistor, unless I'm mistaken here.
If the cathode is shorted to ground, this is true. Other cases, it depends.
Quoted from thedefog:You should be able to find the short by taking your meter and putting one probe on the ground and test all of the diodes on the sockets in that row.
Not really. Since the cathodes are all connected together, if one in a row is shorted to ground, they all are. You would have to visually inspect them to see if you can find anything. You could disconnect the harness connector from the power driver board, then test for any of the row 8 diode cathodes for continuity to ground to see if there is a short, but it won't tell you where that short is physically located.
